Technical Sealer for NPT brake line fittings
Discussion in 'The Hokey Ass Message Board' started by Doublepumper, Apr 1, 2019.
  1. Doublepumper
    Doublepumper
    from WA-OR, USA
    Need some teachin from the experts....I poked around for info, but didn't really find any definitive answers. Can anyone tell me what the proper sealant is to use on NPT fittings used in brake lines? I realize nothing on flare fittings other than possibly a small amount of anti seize on the threads and under the fitting behind the flare. I'm looking at sealing the threads on NPT fittings only and want a sealant that is compatible with brake fluid. I want to do this one time and get it right. Thanks guys!
  2. squirrel
    a little bit of teflon, either paste or tape, should be fine.
  3. 3spd
    3spd
    CNC Inc, a aftermarket brake parts manufacturer told me to use blue loctite on their NPT brake fittings.
  4. treb11
    treb11
    19Eddy30, H380, Rich S. and 1 other person like this.
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    I had read about using blue loctite and was going to use it.....but wasn't sure about it being compatible with brake fluid. Same with the teflon tape or paste. Just wondering if there is something better suited for brake fluid.
  6. Doublepumper
    Doublepumper
    from WA-OR, USA
    This is what I came up with as being the best alternative....don't know.
    John Lee Williamson likes this.
  7. squirrel
    There might be a "best", but there also might be some alternatives that work fine with no problems.
    If you're really worried about it, go ahead and get the Permatex sealer. I've never found a need for it.
    19Eddy30 likes this.
  8. Doublepumper
    Doublepumper
    from WA-OR, USA
    I actually like the idea of using teflon tape, do to it being a good thread filler and lube between aluminum, brass and steel components and fittings. I was unsure if it was compatible with brake fluid that seems to attack most everything.
    I appreciate all of the input you all provided. Thanks!
  9. squirrel
    Brake fluid attacks paint, but it doesn't attack everything. Teflon is tough stuff, not much out there will dissolve it.
    19Eddy30 and Truckdoctor Andy like this.
  10. V8 Bob
    V8 Bob
    It's best to stay away from Teflon tape on any brake/fuel system. Just use any good pipe thread sealant (paste) with Teflon or PTFE, and only on pipe fittings.
    Doublepumper likes this.
  11. 302GMC
    302GMC
    from Idaho
    Never used anything on brake fittings … if a leak occurs, you're doing something wrong.
  12. Yep, you should not need any sealer. If you need some assurance put a dab of teflon paste on the threads.
    olscrounger and INVISIBLEKID like this.
  13. woodiewagon46
    woodiewagon46
    from New York
    Also recommend the Permatex 54540. I use it on the threads and it works great.
  14. Doublepumper
    Doublepumper
    from WA-OR, USA
    Well, I checked my stash of PTFE thread sealers and besides teflon tape I have some Rectorseal and Blue Monster, both with PTFE. I checked the PDS's on both and the Rectorseal specifically states use with brake fluid, so I'll use it and hope for the best. Hate to spend the big money for the Permatex sealant 54540 when I only need a very small amount to do the job. If I didn't already have the PTFE sealant I'd probably give it a try.
    Again, I really appreciate all your input....that's why I'm here!
    bantam and mad mikey like this.
  15. 41rodderz
    41rodderz
    from Oregon
    Rectorseal ? Sounds more like a lower part medicine. Post bathroom break?
  16. Doublepumper
    Doublepumper
    from WA-OR, USA
    It does and would probably be better than nothing......in a pinch.
  17. 3spd
    3spd
    That is only true for flared/tapered fittings - some brake parts use NPT threads and do require the use of sleant.
    Mr48chev and Truckdoctor Andy like this.
  18. I’ve never seen npt brake fittings, where would you see them?
    irishsteve likes this.
  19. prpmmp
    prpmmp
    scotty t likes this.
  20. Rich S.
    Rich S.
    Rectum...Nearly killed him.
  21. OLDSMAN
    OLDSMAN
    I have never seen NPT fittings on brake lines. They are always flare fittings and they require no sealers st all
    54vicky likes this.
  22. scrappybunch
    scrappybunch
    from nj
  23. fatabone
    fatabone
    We have never used a sealant on any brake fittings..
    anthony myrick and Buddy Palumbo like this.
  24. NPT is tapered,and should seal itself.Afraid of corrosion locking parts together? Light coat of anti-seize .
    LWEL9226 and Ralphies54 like this.
  25. I thought you just torqued em down a bunch. Never used anything but the mechanical seal
  26. theres a whole bunch of brake system fittings and parts with NPT pipe threads.
    heres just one and used quite a bit. these happen to have sealer on them already
    jimgoetz, 19Eddy30 and Blues4U like this.
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    I have always used teflon tape, and only had trouble with it one time, and that was a very slow weep with DOT 5 fluid.
  28. OLDSMAN
    OLDSMAN
    Ok if you use aftermarket flex lines there would be NPT fittings, but OE lines are not NPT . Actually NPT fittings shouldn't require any sealer because they are tapered do they seal when tightened
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    In a perfect world taper cut threads would always seal , we all ( should) know , that ain't happening . Thread dope , sealer , paste , tape is used as much as a friction reducer - anti- gall agent as much as anything.
    jimgoetz, tb33anda3rd, Chucky and 4 others like this.
  30. o_O
    I bet there's several dozen different fittings used brake systems that utilize NPT. I don't think you can get all of them into one vehicle, and it's entirely possible to build a brake system without any. None the less NPT brake fittings are out there in force and require some type of sealer.
    19Eddy30 and TrailerTrashToo like this.
