Featured Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. oldiron73
    oldiron73
    from WISCONSIN
    Great stuff!!!!!!!
    I'm hooked.......
  2. weps
    weps
    from auburn,IN
    I think it just refers to the "Deep dutch oven" design.
    the spring, as you noticed, is a F'n MONSTER, simply a wound up leaf spring it seems. On my conversion, I didn't want to use the huge Clark truck 5 speed trans in the Auburn chassis. I used a GM 465 4 speed. there is enough room down inside the "pot" to put a modern pressure plate and clutch, I simply had to drill and tap a few holes.
    Great thread!
  3. CadMad
    CadMad
    My crazy mate has a 46 Seagrave fire truck that was based at Seattle airport. We’ve kicked about plans to build an Edsel Ford 34 boattail roadster. Modenawest posted a swoopy Custom photoshop on Facebook D3407B15-CC45-4370-B3E9-C9AE87901230.png of the original. Now I wonder what it would look like with a V12 stuffed in there.
  4. woodbutcher
    woodbutcher
    :eek::D This just gets better every time I open this thread.Outstanding gentlemen.
    Good luck.Have fun.Be safe.
    Leo
    loudbang, Drmalacarne and Deuces like this.
  5. seb fontana
    seb fontana
    from ct
    Man those chunks of steel for the drums must have cost a small fortune! And the machine work? I bought a 24' 10w19 I beam for a car port and that was $560 +, about a dollar a pound!
  6. WC Durant
    WC Durant
    I like the wood buck. Can't wait to see the body come together.
  7. Drmalacarne
    Drmalacarne
    Due to lack of strength provided by the torque tube, we must had to make a auxiliary arm lateral to the driveshaft linked to the differential house and chassis cross member.
    We cut the steel and made the parts.
    Designed a special new cross member in heavy steel that will serve as support for the mechanical central brakes linkage.
    b1cc0d1e-434d-419e-b0f7-dc8bed4499c4.jpg 72ce5c1b-bcdb-4c6f-be28-d0c92be1e305.jpg 652b909d-b18d-4163-9be5-eb0a19d0025b.jpg 8fb21d96-03c9-49f9-b6fe-1b0213dfd744.jpg fa9f4d96-c213-45af-9886-d0a54298c1e5.jpg 67f96d65-bae5-4c33-af52-e3523ef8b951.jpg 49a407bd-8414-4b82-bf43-4125cb1b93b6.jpg
    And bolted the auxiliary arm to the central cross member with rubber mounts to work in acceleration and breaking.
    Enviado do meu iPhone usando H.A.M.B.
  8. 41 GMC K-18
    41 GMC K-18
    With all due respect to Jay Leno and Wayne Carrini, I hope that they will never be able to own this wonderful machine you are building, a unique machine of this rarity and complexity, with such mastery of metal fabrication and design, this machine deserves to be kept by the man that built it! I am anxious to see some video of it when completed, being driven around there in your country! Now that you have mastered the Seagraves engine, you are more than ready to wrench on vintage liberty V-12 engines, and Hall Scott engines, and Curtiss engines!
    mgtstumpy, catdad49, Jet96 and 5 others like this.
  9. Drmalacarne
    Drmalacarne
    Thanks for your precious words my friend!
    And find engines like you show us is my dream! It’s almost impossible to find them in Brazil.
    dwollam, loudbang, Deuces and 2 others like this.
  10. You guys are doing a great job. Fascinating and innovative. I'm curious as to what timeframe this has taken so far. Seems to be flying along.
  11. williebill
    williebill
    This is so far off the charts, I salute you guys . Amazing stuff. As I started reading about the brakes, I decided that now there's no question that you're insane. In a very good way !
  12. Drmalacarne
    Drmalacarne
    We started the project in January 2019.
  13. Gabriel Bao
    Gabriel Bao
    Hey fellow Brazilian! I read the title and thought about the rat rod that guy built using a marine 12 cilinders engine with turbos. That thing is insane but only useful to do burnouts hahahha. Your project is insane, congrats for the idea and the gorgeous v12 you have!
    catdad49, loudbang and Drmalacarne like this.
  14. captainjunk#2
    captainjunk#2
    i have to post another compliment and state you guys are really top notch at fabrication of this car i cant wait to see the end results
    chryslerfan55, Deuces and loudbang like this.
  15. Cliff Ramsdell
    Cliff Ramsdell
    Wow, making 4 new drums from a chuck of steel, way to go. I love this thread.
    Cliff Ramsdell
  16. weps
    weps
    from auburn,IN
    The long hood almost demands the use of a large engine.
    Although a few of the cars in this thread (including mine) are not 100 percent traditional hot rods, I appreciate being able to post and interact with other builders.
  17. Drmalacarne
    Drmalacarne
    We had to put the steering box far behind because the bigger engine taken all the space.
    And we moved it more to the center to put the steering wheel more central, like an old race car.
    54f8b004-b568-461c-87e9-dcfe151e90ce.jpg b57c9eab-f961-43c3-bb9d-0ae0245b20cb.jpg 8620b2bb-ea43-4935-907d-fa8e7c5da9c5.jpg 31f7fbb0-7f19-48f4-9487-12742aee1a03.jpg
    The steering wheel is a original 1927 Buick unity.
  18. Drmalacarne
    Drmalacarne
    We checked the hubs and changed de old bearings for newer types.
    And adjusted the 20 inches rims.
  19. topher5150
    topher5150
    did you ever mention what the chassis was from?
  20. Drmalacarne
    Drmalacarne
    Yes. The chassis went from a 1926 Buick with 128 inches of wheelbase.
    dwollam, Stogy, chryslerfan55 and 2 others like this.
  21. 41rodderz
    41rodderz
    from Oregon
  22. treb11
    treb11
    mgtstumpy, dwollam, Stogy and 8 others like this.
  23. Drmalacarne
    Drmalacarne
    We put some wood sheets to define the firewall, radiator and seat positions.
    3907a522-39ec-4439-8293-3b77ceb05d8f.jpg cea6b8f0-d158-415a-99e0-722ddc608d37.jpg 9a53769b-6b27-496d-ac95-7f6979f888d9.jpg e7ff38f1-e465-4e73-8367-817ab38f2d58.jpg 0435748f-1fb3-4fbf-94a0-da709b3dc71a.jpg b782d0f7-d62b-4c90-83d2-9d081514a33a.jpg
    mgtstumpy, Thor1, dwollam and 9 others like this.
  24. Drmalacarne
    Drmalacarne
    mgtstumpy, Thor1, dwollam and 8 others like this.
  25. flatford39
    flatford39
    You have a lot longer legs than I do....
    Jet96, tomkelly88, Deuces and 2 others like this.
  26. Squablow
    Squablow
    I love this build. Beautiful workmanship. Looking forward to seeing the body come together.
  27. Drmalacarne
    Drmalacarne
    The steering turns ok!
    We made a extra longer steering bar.
    harpo1313, mgtstumpy, Thor1 and 13 others like this.
  28. treb11
    treb11
    Looks like the tire will hit the bar once mounted on the rim?
  29. Drmalacarne
    Drmalacarne
    Yes! Good point!
    We will make a stop screw.
  30. Drmalacarne
    Drmalacarne
    The wheels fits nicely on the new brake drums.
    And the mechanical brakes don’t looks so bad either.
    mgtstumpy, Lil'Alb, Thor1 and 19 others like this.
