Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. Drmalacarne
    Drmalacarne
    Hi to all.
    Some time ago I bought a very neglected V12 Seagrave engine from a friend an started a nonsense Hot Rod Project.
    I will share here the job with pictures and some words too.
    Please all of you guys feel free to post any kind of crítics, suggestions and other ideas.
    Gui.
    São Paulo Brazil
  2. Drmalacarne
    Drmalacarne
    brEad, flyin-t, Tim and 33 others like this.
  3. Stogy
    Stogy
    That kind of nonsense is already interesting...Go for it and Welcome Hamber...;)
    That's a beautiful Mill...
    Austin kays, Hombre, Saxman and 2 others like this.
  4. Should be a unique project,good luck and more pictures.
    Stogy and Deuces like this.
  5. Drmalacarne
    Drmalacarne
    Later I found a very complete 1926 Buick 128 inches chassis.
    And I thought.... why not!!
    Tim, Peanut 1959, 41 GMC K-18 and 9 others like this.
  6. Boneyard51
    Boneyard51
    That’s going to be fun! Will the engine run! Or at least turn over?
    Bones
    Stogy likes this.
  7. Drmalacarne
    Drmalacarne
    brEad, flyin-t, Hombre and 18 others like this.
  8. Wow! Such a beautiful engine. That's worth building a hot rod around...
  9. Drmalacarne
    Drmalacarne
    After a short trip to get the engine with the original transmission, I put the whole package in the ground if my shop.
    And try to imagine what to do next...
  10. Drmalacarne
    Drmalacarne
  11. 51504bat
    51504bat
    Think Bubba could rework those distributors? bc63e818-8d4e-4557-a381-309241b9a285.jpg
  12. Drmalacarne
    Drmalacarne
    Thanks!
  13. Drmalacarne
    Drmalacarne
    The engine turned over freely when we tried.
    But it reserved some surprises for us after opened!
  14. Drmalacarne
    Drmalacarne
    This is what they looked together after we stripped the chassis and put it aside the V12.
  15. Ebbsspeed
    Ebbsspeed
    41 GMC K-18, chryslerfan55 and Stogy like this.
  16. Drmalacarne
    Drmalacarne
    Bad crank bearings and a lot of old oil sediment inside!
  17. Drmalacarne
    Drmalacarne
  18. Drmalacarne
    Drmalacarne
    The brakes, axles and rear differential are surprisingly complete and in good shape.
    So we started to dismantle and clean everything to start to make the engine/chassis marriage.
  19. Deuces
    Deuces
  20. mgtstumpy
    mgtstumpy
    I'm onboard, should be an interesting build and definitely what you wouldn't normally see.
  21. drtrcrV-8
    drtrcrV-8
    Please post pictures of that engine on the "Unusual Engines" thread as well as this one!!
  22. Drmalacarne
    Drmalacarne
  23. Drmalacarne
    Drmalacarne
    After the chassis rails was cleaned, we cut some thick steel sheets and made internal reinforcements inside the rails.
    The 6 cylinder original engine was a little boy compared to the 531 Seagrave V12.
    Additionally, we moved the engine some 14 inches to the rear, to get a more balanced car.
    Above we can se the final position of the bell house.
  24. WC Durant
    WC Durant
    What are the plans for the rest of the body?
  25. Drmalacarne
    Drmalacarne
    Something like the Cummins Indy Special.
  26. tubman
    tubman
    Boy, I don't know about the ignition systems. I had a '48 Seagrave pumper with one of those that had ignition problems. Luckily for me, the points were the problem. After a lot of lookin' and comparin', I found that '46-'48 Chevrolet points fit. I was lucky that the caps and rotors were good, because I believe they are made of unobtainium. Yours don't look very good. Good luck with it.
  27. woodbutcher
    woodbutcher
    :D Now this sounds like a really fun project.I`ll saddle up and go along for the ride.Welcome aboard Sir.
    Good luck.Have fun.Be safe.
    Leo
  28. WC Durant
    WC Durant
    That will be cool!
    41 GMC K-18, Drmalacarne and Deuces like this.
  29. Rickybop
    Rickybop
    Now that'll be different...
    and really neat.
    For some reason, I like the LARGE early race cars like the one you show. I'd like to have one and drive it.
    Seagraves are quite rare, even here in the USA. But if you search enough, you might still be able to find some parts. I wonder if 6 cylinder distributors could be adapted. Show us how it's done!
    Welcome to the hamb.
    Good luck. Have fun.
    Sent from my VS835 using The H.A.M.B. mobile app
    Stogy, brEad, 41 GMC K-18 and 3 others like this.
