Scrub line??
Discussion in 'The Hokey Ass Message Board' started by shawnsauto1, Oct 21, 2010.
  1. I've done a search without much luck. I'm looking for a bit of a refresher on what scrub line is? I should remember from trade school, but I'm getting old. Any help or direction would be appreciated:)
  2. The point where shit happens if your wheel falls off...:D
  3. A scrub line is an imaginary surface created if lines were drawn from bottom of wheel rim on one side to
    bottom of tire on other side. When lines are drawn from both sides an “X” under the vehicle suspension
    is created. No suspension or chassis component shall be below top portion of this imaginary “X”.
  4. So the concern is usually with cross steer set-ups?
  5. RodStRace
    RodStRace
    Take the tires off the wheels. Install the wheels back in the car and lower it to the ground. The only thing that should touch are the wheels. Anything else that is at or below ground level is below the scrub line.
    The reason this is the law in so many places is that if the worst possible thing happens and you loose 2 or more tires and anything drags, it affects control.
  6. That's it? I thought it was way more complicated than that! I must have been confused with SAI
  7. Fenders
    Fenders
    Beat me to it. Nice and simple.
  8. RodStRace
    RodStRace
    SAI is Steering Axis Inclination.
    Easy way to picture it is to look at a solid axle. The spindles are just about level with the ground (Camber). The kingpin is NOT exactly perpendicular. It is leaned out at the bottom a bit. The line through the middle should hit the ground at the center of the tire that is touching the ground. It's a bit harder with SLA and other IFS cars, but the principle is the same.
  9. Thanks for the help. I thought scrub line was something more complicated. Hate to finish the 27 to find out it's messed up!
  10. 61bone
    61bone
    scrub line- the 40 cars waiting to get in the carwash
  11. DD COOPMAN
    DD COOPMAN
    The above is 'SCRUB RADIUS'...two different critters. DD
  12. missysdad1
    missysdad1
    This is the way the NSRA used to measure it during their safety inspections. It is a bit more forgiving than the way RodSTRace discribed...but not much.
    It's a tough spec to meet if you like your cars low...not MidWest low, but California low...especially if you're running high profile tires.
    So I don't even try to meet it. I design the car so that no unsprung mechanical components extend below the frame...and hope that the car skids straight if I get a flat tire.
    I'll probably get a lot of shit about this...but just ask me if I care. I like 'em low, NSRA or not.
  13. RodStRace
    RodStRace
