Where are some good place to get some scrap steel in the Indy area. I'm looking for some stuff to start metal shaping and could use some direction as to where to go. Thanks in advance.
If you're just talking sheetmetal, I like to cut up old hoods/trunklids and roof skins to make patch panels, any junkyard or body shop should be able to set you up with an old hood for $20 or less and you'll have quite a bit of sheet area to work with. You'll want to pick a newer or older hood based on how heavy gauge metal you want to start with.
