Scored a 59 Mercury
Discussion in 'The Hokey Ass Message Board' started by Fuel to burn, May 6, 2013.
  1. Fuel to burn
    Fuel to burn
    I've been wanting a big cruiser for a while and finally found this on the local CL. It has spent time in Michigan and Massachusetts but it doesn't have much rust. It's hasn't ran in about six years but the motor turns so I'll get it running soon.
    Does anyone know if some good websites for these? I've been searching for sites with good info but I'm not finding much out there.
  2. That thing is cool!
  3. Tnomoldw
    Tnomoldw
    :)Very nice car ,enjoy!:cool::D
  4. Tnomoldw
    Tnomoldw
  5. hombres ruin
    hombres ruin
    slammed and some wide whites...killer ride
  6. swissmike
    swissmike
    What's up with the camera? Are you usually shooting soft porn? ;-)
    Cool car - I don't think I have seen one before.
  7. jesse1980
    jesse1980
    Cool car, 2 door? I can't tell from the pictures.
  8. garvinzoom
    garvinzoom
    Yes, two door.
    Beautiful car! Congratulations.
  9. 40grit
    40grit
    You have to remember I am an old Fart but I owned a '59 Merc Park Lane convertible back in 1965. What a tank but I loved that old girl. :D
    John L
  10. You most definitely scored! Good job! More pictures please.
  11. black 62
    black 62
    from arkansas
    american decadence ---i love it...
  12. Bigcheese327
    Bigcheese327
    What a beauty - '59 was a good year for Ford products.
  13. Green Rodz
    Green Rodz
    Ditto;)
  14. rld14
    rld14
    Beautiful car! Montclair... Does that thing have a 383 in it? If so plan on changing the timing chain and gears, dropping the oil pan and at the very least cleaning the pan and pickup screen, ideally changing the oil pump and oil pump drive shaft (use an FE shaft and shave .075 off the end).
    The timing gears on MEL engines are nylon coated, the nylon breaks off with age, clogs the oil pump and bad things be happening. A quick fix will save the engine.
  15. 40grit
    40grit
    Good info and well worth listening to. My 383 was bad to collapse lifters every time I really got on it. If you ever dropped it in passing gear it would sound like a thrashing machine until each lifter pumped itself back up.
    John L
  16. Reman
    Reman
    from Florida
    Maybe it has a 430? They were out in 59 for some Mercs and Tbirds. My friend had a 59 with a 430 when we were teenagers, and that thing was a real street screamer. You got a great car.
  17. Belchfire8
    Belchfire8
    Nice car! It looks very solid so it must not have spent too much time in Michigan. When I was a kid the preacher across the street had a '57 four door Merc. It was the mid '60's and it had already had bodywork (crappy) and a repaint due to rust.
  18. Fuel to burn
    Fuel to burn
    I'm pretty sure it's got the 383 since it has the two-speed trans. This is my first MEL engine so I don't know them too well. I've been looking for engine codes but can't find them.
    Does anyone out there know how to tell for sure?
    Great news, it drove around the block today.
    I took the plugs out and put in fresh oil and filter. Then I spun it and the oil pressure came up so I compression checked each cylinder. All were near 150 except #5 at 120. I pulled the valve cover but nothing was amiss.
    I cleaned up the points and got good spark from the coil so a new set of plugs went in. I cranked it and got it running but it was really rough.
    Then I realized I hadn't hooked up the right side plug wires!
    After hooking up all the wires it ran much better and I got the carb dialed in really well and she's really smooth even at low idle so I'm not sure what to make of that weak cylinder.
    Tomorrow I start going through the brakes.
  19. Motomike43
    Motomike43
    That is sweet!
  20. rld14
    rld14
    That's not a 2-speed trans, its a 3-speed. It's a dual-range, you actually want to use D1 not D2. In D1 the car starts out in 1st, in D2 its a first gear lockout.
    Weak cylinder could have been dry or sticking rings, also you're supposed to compression test MELs when they're hot.
    Glad to see ya got it working tho! I love 59s and really miss mine.
  21. sololobo
    sololobo
    What a cool ride bro, super dooper score. Some good times ahead in that beauty! ~sololobo~
  22. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Awesome ride. Screams of late 50's Americana. You don't see many 59's-especially 2 doors.
    X3 on the lowering with WWW's!
    Join the HAMB Merc club (Bad Bob).
  23. arkiehotrods
    arkiehotrods
    That is a sweet ride! If you have 150 lbs compression in 7 cylinders and 120 in 1 cylinder, drive it!
    According to my reference book, they only made 7,375 Montclair 2 dr hdtps in '59. You will likely go years without seeing another one at a show.
