I have a 341 y-block in my 55 Lincoln.My question is,are the 272,292 and 312 external motor parts interchangeable with the 314. I am wanting to install a/c to beat the Texas heat and i know i will be needing quite a few brackets...thanks for any help
look for the lincoln engine group on the hamb and look on ford trucks the big f700 and up 302 332 have a lincoln y block also the tilt cabs used them, they have rams horns exhaust, a holley 4 v intake the regular holley patern and the oil pan is flat and high cap?
Try doing a google search for John Mumert. He knows a lot about y-blocks.....to the point where he manufactures his own parts as well as builds engines. I bet he could answer any y-block question you throw at him.
In short, no. Two different engine families. What type of compressor are you wanting to use? Is this a stock setup or modified? http://www.ford-y-block.com/lincoln.htm Showing 1956 MARK II with factory air install-
