School me on '36 Ford wide 5 wheels
Discussion in 'The Hokey Ass Message Board' started by Jeem, Jul 29, 2009.
  1. Jeem
    Jeem
    Alliance Vendor
    ElPolacko, here on the HAMB, hooked me up with 4 of 'em! I've got the krusty tires demounted and found that 3 of them are 4 inches wide, one of them is 3.5" wide.
    What years and model cars and trucks ran this wheel and what are some differences?
  2. chaddilac
    chaddilac
    I thought those were 37 to 39?? 36's had wire wheels didn't they.... or late did late 36 switch to wide 5's??
  3. Jeem
    Jeem
    Alliance Vendor
    The book I have on these pickups shows wires on the '35 only and the artillery style on the '36 and '7.....
    Anyone know why they are two different widths (3.5" and 4")?
  4. ardunpinto
    ardunpinto
    from WACO tx
    If you look on the wheels they have dates on them, might be hard to see but they do.
  5. Alienbaby17
    Alienbaby17
    I'm no expert but I believe the wide fives were used (at least on cars) 1936-39. I believe the different widths may have had something to with whether you had the bigger V8 or the V8 60 engine.
    Jay
  6. Revhead
    Revhead
    from Dallas, TX
    I also have some wide fives and noticed the other day that two of mine are slightly different. They have smaller "holes" between the spokes. The area around the lug nuts is slightly different too.. There must be some different varieties out there.
  7. Jeem
    Jeem
    Alliance Vendor
    Okay, you guys don't tell anyone....I might run the oddball 3.5"er...
    hahahaha
  8. Revhead
    Revhead
    from Dallas, TX
    found this on another board
  9. Jeem
    Jeem
    Alliance Vendor
    Okay, so 3 wheels, pretty much the same, all within an inch of each other?! You'd think Ford would'a just went crazy and pushed the envelope with a nice 5 incher too.....
  10. Bib Overalls
    Bib Overalls
    The 3.5 is worth more than all three of the 4.0s.
  11. '36-'39 regular V-8 cars ran the 16x4" wide five wheels. 60hp cars had the 3.5" wheels.
    Sizes remained the same in '40 but they were, obviously, a 5x5.5" bolt pattern "steel" wheel.
    JH
  12. Jeem
    Jeem
    Alliance Vendor
    Hmmmm, are you putting wide 5's on the RPU?
  13. Ratty55
    Ratty55
    from Frohna,MO
    Didn't they run a wider wide five wheel on the Lincoln zephyrs? If you can find a set of General Jumbo? wheels, they were 15 inch wide fives and don't actually have the "spokes".
    Justin
  14. NealinCA
    NealinCA
    They did...39-41 3/4-ton pickups used a 16x5 wide five wheel. They are not scalloped like the 36-39 car wheels though...they just have 5 slots.
    Here's one of the 5" wide 3/4-ton wheels on the back of my rpu...
    I am running the 3.5" wide 37-39 V8-60 wheels on the front...all with 36-37 Lincoln Zephyr caps.
    Neal
  15. NealinCA
    NealinCA
    No. 36-38 Lincoln Zephyr used the 16x4" Ford wheel.
    Neal
  16. My '39 Mercury sedan has these wheels (16x4). I am planning on pulling the axles out from under it and using them on my '27 coupe. I have all 5 wheels and a full set of original Mercury hubcaps. The cool thing about the Mercury axles is that they had hydraulic brakes from the factory in '39. I haven't decided whether to sell off the rest of the car or put a later rear end and maybe a MII front under it and keep it.
  17. NealinCA
    NealinCA
    So did Ford...
  18. I wasn't sure which year Ford started but am glad to learn something new.
  19. cvstl
    cvstl
    from StL MO
    1. H.A.M.B. Chapel
    The 3.5s are hard to find.... should be easy to find another 4 incher, though.
  20. DICK SPADARO
    DICK SPADARO
    Your 3.5 " wheel is off any 37-39 60 Hp Ford car. Other than being different in width I do not see that it should be any more advantageous or desirable than the normal 4" wheel. The 1/2" bead width is not going to be a noticeable difference other than fake hoopla to pump up the uniqueness to make a buck. The hard to find 3 1/2"x 16" wheel is one from a 1940 ford 60 hp The more sought after wide 5's are the pickup units that are wider in width, 16" x5", and the Marmon-Harrington 15" wide 5's.
  21. scootermcrad
    scootermcrad
    Wide Fives RULE! Really cool wheels! There are MOUNDS of these wheels out there laying around for cheap. If it were me, just to be consistant, I would pick up another one that's 4". As already stated it probably doesn't make much of a difference other than you're pushing the limits of most tire specs (in terms of recommended width).
    I'm running 600x16's up front and 750x16's out back. I may elect to have the rears widened to 5 or 5.5 inches, at some point.
  22. Revhead
    Revhead
    from Dallas, TX
    can someone explain this wheel? I have 2 of them. It is 16x4.
    Mine is the white one, the other is for comparison.
  23. SinisterCustom
    SinisterCustom
    I've got "access" to a pair of the wide 5's that are 3.5" wide....would it be to my advantage to get 'em by swapping 4 inchers for 'em???
  24. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    WheelKid has 3.5"ers available on his site, or at least they advertised. They cost a bit more then the 4" but they are there. I have 2-3.5" and 2-4" waiting to be used on my coupe.
  25. Jeem
    Jeem
    Alliance Vendor
    Yep, that's the plan....the 3.5 may be more desirable, but I just want 4 that match.
    Interesting. The black wheel is the one we're discussing here. It's spider has a flat face and larger holes, while the white one has a spider with a rounded face and itty-bitty holes, plus it has more meat around the stud flange.....wonder what they are from.
  26. Revhead
    Revhead
    from Dallas, TX
    the white wheel came off of the argentine '38 cabriolet/pickup thing. It had 2 normal ones and 2 of those. So it could be off almost anything. Are the ford ones stamped ford somewhere?
  27. E Burfield
    E Burfield
    I just picked up a pair of 18'' wide fivewheels. what would they happen to be off of ? sorry not trying to hi jack.
  28. scootermcrad
    scootermcrad
    If you don't mind me asking, what did you pay for them? I'll trade you some 16" wide fives for them. :D
  29. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    The 18" wide fives are a Kelsey Hayes accessory wheel that is pretty rare. That's a hell of a score and probably worth a $500-1000 I would think. Not exactly sure what ran them but I assume it was a truck.
  30. scootermcrad
    scootermcrad
    SHHHHH!!! Jeesh! Trying to get a trade going here for my AWESOME 16 wheels. ;):rolleyes::D
