Hot Rods SBC's that are anything but orange.
Discussion in 'The Hokey Ass Message Board' started by BLACKPRIMERFAN, Mar 28, 2015.
  1. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    Larry,
    I always tried to use all the crayons in the box. They almost held my back in kindergarten because I colored my sky's purple & my trees red! At least I wasn't the kid that ate the paste in the boom closet... I wonder what he does fort a living now days??? Probably should leave that one alone.
    Some nice looking engines being posted, keep them coming.
  2. Hot Rods Ta Hell
    Hot Rods Ta Hell
    57 265 factory painted Chartreuse;
    tb33anda3rd likes this.
  3. BamaMav
    BamaMav
    from Berry, AL
    My Ford Blue 350
  4. attachment-3173485776.jpeg Can I get half credit for this? It is a 181 cubic inch Chevy Industrial engine (sort of half a SBC) painted Ford engine green in my '32 roadster.
    Charlie Stephens
  5. Sail Blue 350 in my 1953 Bel Air roadster with a Carson-style top.
  6. foolthrottle
    foolthrottle
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    I painted the sbc in my 23 Hummer Fusion Orange, but it was more like a bronze color.
    Don
    TS057, Montana1, Speedon and 4 others like this.
  8. Road Angels
    Road Angels
    Not deere my frame is Deere thats not close
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    truth be known, I have no room to talk. I painted the 327 in my coupe flathead ford green :eek:
  10. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    Well looks like I'm using a color other than orange as long as I'm getting my block dipped. I'm leaning towards that duplicolor diesel green or maybe metallic Pontiac silver-blue? Are you guys smoothing up the blocks much before spaying them? And are you painting them before assembly or after?
  11. cheepsk8
    cheepsk8
    from west ky
    I painted one once, silver and black to match the truck, blew it up, next one orange, blew it also, finally threw together a 283 NO paint, grease stains and all, it was in it when I sold it. I'm color blind anyway so it doesn't really matter here. I have always heard that painting one black would cause it to run a few degrees hotter? Wonder if that is true.
  12. Karl Fields
    Karl Fields
    They came in orange? :)
    I couldn't decide on a color so went with the all color black.
  13. DDDenny
    SINNER
    3wLarry likes this.
  14. In this case I chose to color match the engine to the car. IMG_0775 - Copy.JPG
  15. theHIGHLANDER
    theHIGHLANDER
    It's the opposite, it runs cooler. Now that applies mostly to it being a satin black vs a glossy show rod finish. At that point any color can add a few degrees but not enough to make much difference. 14:1 BBC, all satin black, electric motor driven water pump and fan, 160 stat, 3 row OEM style radiator. I had a hard time getting that car up to temp. I'd do my burnout and begin to stage with the fan/pump off, turn it on and lit the lights at 175 degrees. By the time I got to the ET shack it was down to 160. The black paint thing works well and I had all of it black including the intake. Just sayin, and thanks for this topic. I love alternative colors. I really like that bright green version shown. Reminds me of the Duesenberg green on the J models. Gold is always a favorite too and seems to go with anything.
  16. Any color as long as it is what came from the factory:cool: Chevy's But I must admit that 3wLarry's Ford green on that 32 is very cool! Other than that I like RED Motors
  17. Ragtop
    Ragtop
    Paint it any color you want - haven't seen any paint police around for a while. here's mine: [​IMG]
    Montana1 likes this.
  18. I always had better luck with a brush than spray.
    Charlie Stephens
  19. cheepsk8
    cheepsk8
    from west ky
    Thanks HIGHLANDER for setting me straight, next one's black.
  20. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    You would almost think an unpainted block would run cooler? And that any paint traps the internally generated heat in, more less? Then again... Maybe not? Where's Bill Niegh the Science Guy when you need him?
  21. atomickustom
    atomickustom
    Smoothing the casting theoretically interferes with cooling. Adding any paint theoretically interferes with cooling. So a bare block should shed heat better than a smoothed bock with heavy layers of epoxy paint. But the heat doesn't care what color the paint is and if flat black "cools better" it's probably because it goes on a lot thinner than a heavy gloss enamel.
    I have never seen any scientific research showing that paint makes a significant difference when so many other factors make such a big difference on engine cooling, but in an "every bit helps " situation it could tip the scale slightly? But only slightly. (Paint doesn't insulate THAT well!)
  22. sunbeam
    sunbeam
    From internet site factory colors.sb cars from 55-66. Orange 55,56,58-66 Red 55,56 Chartreuse 57 265. Truck Orange 57,63,64 Yellow 55,56 Gray 55,56,58,59,60,61,62,65,66 Green 57,58,59,60,62,65,66 Black 57 blue 66
  23. That is not quite correct. Passenger car 1956 V8's were 265 cu.in. and were painted red from the factory.
  24. Is red OK?
  25. No, That's why they paint wood stoves and radiators black, to dissipate the heat.
  26. sunbeam
    sunbeam
    According to the chart they used both red and orange in 56.
  27. verno30
    verno30
    Black
    White
    Red
    Gold
    Blue
  28. 1950heavymetal
    1950heavymetal
    Hey Larry, the chev engine pic you posted, if you dont mind me asking, what brand exhaust manifolds are you using?
