I am in the process of putting together a tri power setup for my SBC using small based 2gc carbs. I have two carbs with side fuel inlets, one with an end fuel inlet, and a parts carb with a side fuel inlet. Can I switch the top of the parts carb with the side inlet onto the carb that has the end fuel inlet?
Look up the bill-of-materials for each carb by tag number. If the airhorn gasket is the same for both - MAYBE. Now check the alignment of the pump arm/pump. If the two have different airhorn gaskets, then probably not. Jon.
