Yep!!!.....it's gotta be clean (no oil/no film) I agree doing it with the engine still in the car is wayyy harder. 6sally6
Update....after 3, top of the line, pan gaskets, both with and without gasket maker and 2 rear main seals, Felpro dual lip, I decided to bite the bullet and order a new pan....Milodon gold anodized steel...this pan is pricey but is much heavier (gauge) than the aftermarket pan that was on the car....and a Milodon pan gasket......20 mile sprint down the highway and back.............NO leaks whatsoever.....pricey but took care of the issue, 100%. Thanks for all the ideas guys, this one had me scratching my head...never had a pan leak before (my background is in Mopar).....
This isn't a bad way to go for those problem child jobs now and then. I suggest also a cheap investment into making it easy to pull off. Get 4 longer socket head (allen) bolts to use as studs and put a pair on each side to act as guides and preserve the seal bead as it's raised into it's final set. Something like 1" ought to work and plain ol 1/4-20 nuts will finish the job. Sound like I've done it too? I even do it with gasket and Permatex jobs. Too lazy to hold it place and start bolts
Yeah ...the Felpro gaskets I used had 4 blue studs, one for each corner that had snap shoulders on them...slid pan and gasket up into place and these studs held everything in place AND the pan up against the block while you got all the bolts started.....way handy
