Hot Rods SBC Offenhauser Valve Covers
Discussion in 'The Hokey Ass Message Board' started by Hotrodmeister, Feb 24, 2016.
  1. Hotrodmeister
    Hotrodmeister
    from Virginia
    I am trying to build a period correct late 1950s Small Block Chevrolet engine and wanted to know if Offenhauser made valve covers with oil fill holes/breather holes in the 1950s or are the reproductions I see that have these holes merely modern creations and not period correct? Any help with this would be greatly appreciated!
  2. swifty
    swifty
    In my Weiand 1965 catalog it shows valve covers for 55-58 Chev(265-283) and 58-65 (283-327) and pics of both covers do not have any holes for oil fill or breather.
  3. badshifter
    badshifter
    Chevy did not have the oil filler cap in the valve cover until the mid to late 60s so I doubt the aftermarket would've done it in the 50s.
  4. Hotrodmeister
    Hotrodmeister
    from Virginia
    Thank you so much for your input! I really appreciate it. Sounds like I am better off going without the holes on the valve covers to play it safe!
  5. Sting Ray
    Sting Ray
    I'm not sure, these are an old crusty pair I polished. No idea how old. Weiand V C 1.JPG Weiand V C 2.JPG
    LOU WELLS likes this.
  6. Speed Gems
    Speed Gems
    55- to mid 59 valve covers had staggered bolts so these would be '60 or later valve covers.
  7. Old-Soul
    Old-Soul
    Pretty sure those Weiand ones above are late 60's at the earliest.
    I have some staggered hole Offy covers from around '56, no breathers.
    Since the early engines had their fillers on the intake they just had a breather cap as well as road-draft tubes on the rear.
  8. Hotrodmeister
    Hotrodmeister
    from Virginia
    Does anyone have any Offenhauser valve covers without the holes they are willing to part with? I need the ones with straight across bolt holes.
  9. Jokester
    Jokester
    Good luck in your search for these. I looked for 2 years before I found mine. Semi rough and still had to pay 200 plus the ride.
    swade41 likes this.
  10. Old-Soul
    Old-Soul
  11. 49ratfink
    49ratfink
  12. Russco
    Russco
    from Central IL
    Are you dead set on Offy? If not Weiand and Cal Custom would be period as well. and probably much easier to come by. Weiand may re-pop the early versions still.
  13. Old-Soul
    Old-Soul
    Weiand can be quite spendy as well, but are way-cool. I've not heard of modern repops of the original covers.
    Cal Custom are cool too, although many back-in-the-day looked down on them as cheap, and can be a very "cost effective" alternative now. There's a nice set of 9 fin Cal Custom covers on eBay as we speak.
  14. Speedway sells them brand new - if you want to look like an early motor I believe they make an adapter for the staggered to straight across bolt application- run the early covers with no holes- not cheap but you will achieve your goal
  15. Gman0046
    Gman0046
    On eBay, someone is selling new no hole covers that appear to be copies of the old Cal Customs in the $70 range a pair.
    Gary
  16. Hotrodmeister
    Hotrodmeister
    from Virginia
    I really appreciate everyone of you guys taking the time to help out!
