SBC motor mounts
Discussion in 'The Hokey Ass Message Board' started by Gus68, Feb 13, 2010.
  1. Gus68
    Gus68
    from Minnesota
    I know I know.... I've tryied the search as many different ways as I could think of and can't find what I'm looking for. All I am doing is trying to come up with some cool ideas for motor mounts for my small block chevy in my Model A. The motor is out in the open so everyone can see it so I thought the mounts should look cool, yet not too funky or clunky. Everything I have come up with looks like crap, so lets see em!!!! I KNOW I am not the only one with a sbc in an old rod!!!!! Ya I know, small blocks are done to death.
  2. dbradley
    dbradley
    I've always been partial to SIMPLE.
  3. Go with a set of biscuits bolted to the front mount bosses.
    Bunches of them out there.
  4. 51 mercules
    51 mercules
    Hurst mount and biscuits.
  5. Gus68
    Gus68
    from Minnesota
    Ya, I was thinking of a hurst or hurst style front mount but I just don't have the room. So I need to go with some sort of side mounts. I know I'm being kinda picky but the look I would like is to make a mount that looks like a factory part, if a small block happend to come standard in a model A. If that makes any sence????
  6. Deuce Roadster
    Deuce Roadster
    Simple, strong easy to make and easy to install :D
    Uses a factory style rubber SBC motor mount for a mid 60's Chevrolet
    ... so replacements are easy to find and very easy to install when and IF you ever need to. :)
  7. crackerass54
    crackerass54
    from dallas
  8. Mr48chev
    I saw this on a T bucket but it would be easy to build something similar and possibly a bit cleaner.
    If you are going to run a rear transmission mount you do not want a Hurst style mount on the front of the engine. That setup can allow the engine and trans to flex at the bellhousing causing front seal failure in automatics. It works great with a setup with the rear mounts on the bellhousing though.
  9. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    KennysRodandKustom on ebay has a bunch for about 75 bucks. Got them for our roadster, and was please with the look and fit.
    Louie
  10. slddnmatt
    slddnmatt
    made these the other day. thought i had a pic of the lower part also but i guess not:(
  11. NM Sandrail
    NM Sandrail
    Hi Gus68,
    Here is a photo of a pickup truck's motor mounts that I saw at the Swap Meet @ Springfield, MO last August, the day before the HAMB Drags @ MoKan. I photographed it for future reference... A bit unusual as it was set up to allow steering shaft through and probably also gave the frame some additional strength, by tying the rails together... Anyway, just a thought...duane
    http://www.pbase.com/nmsandrail/image/116600584
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    UH, that would be a factory 58-64 style V8 motor mount, wouldn't it?
    Factory part in a factory car. What's simpler? Last long as your life, cheap, and available at every parts store in the US.
  13. renrob5000
    renrob5000
    I'm partial to these by Brian Bass...[​IMG]
  14. vendettaautofab
    vendettaautofab
  15. Very good point.
  16. kaydub
    kaydub
    from Cali
    here is what's on my dad's car...
    FINISHED
  17. Gus68
    Gus68
    from Minnesota
    Hey! Thanks for the pics guys!!! I tryied an idea I had after looking at some of these, I'm not quite done but i'm not too sure if it's what Im after, but whats the worst that could happen? it turns out loke crap and I have to start over again? Good thing I like making stuff!!!
  18. vendettaautofab
    vendettaautofab
    Thats what its all about man, good for you. Its only metal.
  19. hotrod40coupe
    hotrod40coupe
    I'm using the Vern Tardell ones that mount on the front of the block and use the stock Ford biscuits.
  20. Gus68
    Gus68
    from Minnesota
    Question about those biscuts, I know speedway sels them, but I deal with NAPA alot, and was wondering if there is an application (year make model)that I could ask for, or is it a speedway thing?
  21. Bill Van Dyke
    Bill Van Dyke
    Look up Chassis Engineering, lots of options
  22. need louvers ?
    need louvers ?
    Hey gus, ask the counterman to look up Ford mounts from 1940 - 1948. They will have them, but I think you will find the price a bit steep in comparison to the early Ford aftermarket. might be better than waiting for mail order though...
  23. harrydude
    harrydude
    from ab
    what about a bushing from a big rig they seam o be the samish......
  24. Jingles
    Jingles
    I like Moroso metal mounts. They are neat and strong OR modify them and add a rubber bushing if you have unwanted vibrations.
