sbc fuel pump
Discussion in 'The Hokey Ass Message Board' started by 1929rats, Jan 9, 2010.
  1. 1929rats
    1929rats
    Is anyone manufacturing a sbc low psi pump (under 7psi)?
    I was told carter does...I see one for sbf but not sbc
    Thanks,
    Pete
  2. Ayers Garage
    Ayers Garage
    Any generic parts store replacement should fill your need.
  3. Mr48chev
  4. I,m thinking he means an electric pump.....a stock pump would be too obvious.
  5. Ayers Garage
    Ayers Garage
    I figured since he told what engine he meant a mechanical pump.
  6. ChevyRat
    ChevyRat
    Just get a fuel pressure regulator
  7. SYCO620
    SYCO620
    from Merced, Ca
    What he said.
  8. 1929rats
    1929rats
    I want to get away from a regulator....and I know I could use a stock Gm pump for a 283. and I appreciate that link, but I think I should have spelled out my request better. I was looking for a mechanical pump under 7psi with a clockable lower housing. The geometry of my car makes this a challenging request.
    I dont want to run a fuel regulator off a fuel block from my firewall. I also dont want to run an inline regulator like mr gasket offers (clock like dial). I figured that there may be a mechanical pump somewhere with an adjustable lower housing offering under 7 psi somewhere so I can have "a cleaner presentation" if you will...rather than having to run the fuel line to a regulator then to a multi carb fuel line...
    Thanks guys for the answers.....I reallyappreciate it...I should of been more thorough up front....
  9. checking napa's website , i found this one for a 1963 chevy...part # M3120. they claim it puts out 5 to 6.5 PSI. it looks like you could turn the lower part
  10. Ayers Garage
    Ayers Garage
    I just searched Summit and they have pages of mechanical fuel pumps for SBC that put out 7 psi or less and are clockable as needed to get the fittings in the proper place for your chassis. Just choose your preferred brand.
  11. 1929rats
    1929rats
    well shit.... I feel Real stupid.....I was looking for carter stuff in particular as thats the brand I was told, but, that napa part will work great....thanks....
  12. tfeverfred
    tfeverfred
    Edelbrock has one that's 6psi. I got one a month ago and it's doing great.
  13. yekoms
    yekoms
    Like said above. Edelbrocks work and are like the Carter street pumps which are no more.
    Smokey
