Today i discovered the threaded hole in the front of the block that goes through to the fuel pump pushrod bore, doesn't. It's a blind hole, doesn't go through to the bore. Did GM change this a some date? Has anyone ever drilled and tapped the hole, or know anything about doing it? The reason i ask was I planned on using a roller tip pushrod, and that hole is required. Thanks
I can't say I ever noticed a block that wasn't drilled through and tapped except a later versioin that had no fuel pump rod hole such as some later vortec versions. Just finish drilling the hole through and tap it if you need more threads.
