Projects SBC front mounted Dist
Discussion in 'The Hokey Ass Message Board' started by sdluck, Apr 23, 2016.
  1. badshifter
    badshifter
    If any part of any oil pan hits a model a axle then you really f-ed something up badly.
    Ned Ludd likes this.
  2. gimpyshotrods
    gimpyshotrods
    You got that right!
  3. sdluck
    sdluck
    No It is just getting finished now,it is also a 427 and it is going together with a holley for breaking it in.What cooling system,any heating problems?
  4. sdluck
    sdluck
    I have a belt drive oil pump with a hilborn fuel pump bolted to the back of it..
  5. sdluck
    sdluck
    I did the same thing when I had to pull the intake.
  6. DDDenny
    Stewart pump, Steve Long Indy huge by heavy radiator.
    Only dyno time since assembled.
  7. sdluck
    sdluck
    Stick or automatic
    Would you mind sharing some of that information?
  8. DDDenny
    Richmond Super T-10, 2.64 first IIRC.
    falcongeorge likes this.
  9. gimpyshotrods
    gimpyshotrods
    I will see if I can dig up my notes. The last time I tried was over the winter between 1999 and 2000.
  10. sdluck
    sdluck
    What heads,cam and what did it dyno?
  11. DDDenny
    Air Flow Research 210 cnc comp ported heads, Crane hydraulic roller, Isky rev kit, Smith Bros. pushrods, Donovan fixed idler gear drive.
    Callies/Wiseco rotating assembly, 10 to 1 c.r.Dan Olson kickout pan, 1&3/4" S&S headers.
    McFarland torque link intake and Braswell 750 Holley carb, MSD ignition.
    Pretty small numbers from dyno, 450 hp. After trying dyno shops intake manifold and 1.6 rockers, 465 hp.
    This engine is a street build for a light car so we weren't trying for big numbers.
    Tim_with_a_T likes this.
  12. DDDenny
  13. sdluck
    sdluck
    Whats it weigh?What rear end and gear,I have a t 10trans ,heads are brodix wild thing
  14. DDDenny
    Just a guess, maybe around 2200 lbs. Nine inch Ford housing out of 57 1/2 ton p.u. Strange alum center, Detroit locker, 3.50 gears, Dutchman axles.
  15. sdluck
    sdluck
    My car is a full fender 29 roadster sbc ,turbo 350 ,pont rear weight in at 2340,with the rodeck,cast iron T 10,and winters quick change I expect to drop a few pounds
  16. DDDenny
    I showed mine, what's the skinny on your engine.
  17. sdluck
    sdluck
    Old sprint car block,I had it welded up ,8 new sleeves ,no oil pump mount on rear main, hence the belt driven oil pump/fuel pump, Scat 4 inch crank ,roller cam,brodix wildthing heads.I will break it in with a victor intake and holley ,and later running Hilborns. My friend used to build sprintcar motors here in san jose is doing the machine work..I have had life get in the way so back at it.I have a cast iron T-10 and will be putting a winter quickchange. Anything else I can answer for you.
  18. Just cut a hole for the dist. and add an early heater box on the inside to cover the hole, you can open the heater door and adjust the timing while you drive.
    turboroadster likes this.
  19. DDDenny
    Is your block one of the lightweight sprint car blocks or a drysump version of the standard 350 plus block?
    When all done, let us know the outcome, I'm jones'n to get mine on the road too but as you said; life seems to get in the way.
  20. sdluck
    sdluck
    I will keep in touch ,it is a 350 /400 block, what flywheel are you running?
  21. DDDenny
    Hays #10-130, Centerforce clutch.
  22. 29moonshine
    29moonshine
    this i like
  23. sdluck
    sdluck
    No hei ,MSD small cap.
  24. gotit
    gotit
    Look at the early 60's Chris craft 283. They were mounted backwards in the boat (flywheel forward) and had the distributor off the cam and a block off in the stock dizzy hole. The dummy dizzy drove the oil pump and also had a tach drive on it. It's reasonably priced parts.
  25. Speed Gems
    Speed Gems
    An engine builder buddy of mine just so happens to have a pair of 283's he says are from a Chris craft that he sent me a picture of.
    16833503_10208794473360850_394548044_o.jpg 16833504_10208794473080843_933318137_o.jpg
  26. sdluck
    sdluck
  27. sdluck
    sdluck
    It is too long to get out of the block.
    Any body have pieces for this boat set up please pm me,reasonally priced please?
  28. GMC BUBBA
    GMC BUBBA
    Accel (older ones) distributor has a removable top . Usually on ebay etc......good unit .......
  29. sdluck
    sdluck
    Dual point or Electronic what number should I look for?>
  30. DDDenny
    How's that "little" Rodeck coming along?
