i just got 4 single barrel re built CARTER carburators any one know if there is any 4x1 barrel sbc manifolds? 2 bolt mount thanks in advance
you could make a 4x1 intake out of a dual quad intake. there are all kinds of adapters that bolt up to four barrel bases. i have seen adapters that mount 2 three bolt carbs to a four barrel base. there are also carb adapters from offenhauser that adapt 3 bolt carbs bases to 2 bolt carb bases and vice versa. it would really put the one barrel carbs up kind of high but it would look cool. not sure how well it would work. should be able to run progressive linkage.
