SBC / 283 in a shoebox ford coupe
Discussion in 'The Hokey Ass Message Board' started by Butch54, Jun 25, 2013.
  1. Butch54
    Butch54
    from tree house
    hey all....
    I picked up a shoebox ford with a bad motor (flathead).. I am thinking of dropping in a 283 or 327 sbc and know I will convert to 12V. Can someone give me advice or possible detours i may encounter with this engine choice.. I know this is probably a common thing with classic ford's and sbc motors... I believe I will need after market motor mounts, and will i need a special oil pan to fit and will the exhaust manifolds fit around the steering box? will my stock shoebox ford 3 speed tranny work with the motor? appreciate any help here "before" I get the motor I want to map out what is needed to help save a few headaches... Not my first hotrod, but first with this configuration..
  2. 68vette
    68vette
    Check with Honest Charley's in Chatanooga TN...that would be a good start...should be able to get you a bell housing and other parts I am thinking.
  3. gwayne
    gwayne
    oil pan from a nova i believe.
  4. Tank
    Tank
    Ill be honest with you. I wouldnt run the stock 3 speed behind a sbc. I suppose it could hold together but its a heavier car and with the torque of a small block compared to a straight 6 or a flathead.... hmmmm
  5. Buz
    Buz
    I put a 327 and a turbo 350 in my 50. I found a dropped center link for the steering because the Nova oil pans are very pricey. I had to cut the drivers side exhaust manifold and rotate the flange and angle it toward the block a little. I had a friend weld the cast iron, still good after 10 yrs. The trans cross member just needs a notch for the mount. The trans tunnel needed to be enlarged also. I think you can still get the mount kit from Butch's Rod shop( not sure of the name).
  6. daddio211
    daddio211
    First, join this group: http://jalopyjournal.com/forum/group.php?groupid=127
    Then read this thread in its entirety: http://www.jalopyjournal.com/forum/showthread.php?t=296506
    Read it, memorize it, love it.
    SBC swaps in shoeboxes is common, but most guys agree the exhaust manifolds are the most difficult part of the install. Don't quote me on this, but I think the ones that work best are the late 80's Camaro cast iron units. They come UP a few inches, then drop down at the back of the engine.
    Check out the thread in the group listed above called something like "Post shoebox build threads here".
  7. gwayne
    gwayne
    I would recommend that link provided by daddio211.. personally I would use a saginaw man trans over a TH-350 TRANSMISSION. I saw a couple of the Nova oil pans on e-bay.. also jamco sells the engine/trans conversion kits, a little spendy but worth it..
    http://www.jamcosuspension.com/products/sfID1/3/sfID2/132
  8. daddio211
    daddio211
    Don't buy ANYTHING from Jamco! You'll pay for it but you'll never receive it!
  9. gwayne
    gwayne
    That sucks... you must have personal experience hey....:(
  10. tedster
    tedster
    Do a search, it is well known Jamco has problems. Don't give advice if you don't know what you are talking about.
  11. lorodz
    lorodz
    I used butchs cool stuff mpumts in my sbf I to my shoebox fit like a glove...made in the u.s.a. and it really nice parts give em a call the are h.a.m.b vendors you even get a discount.good luck
    Oh and they will answer any questions you have
  12. JeffB2
    JeffB2
    from Phoenix,AZ
  13. lorodz
    lorodz
    I ised the butchs cool stuff in my shoe box witha sbf from a foxbodie mustang witha t-5, the mustang radiator, tubular shorty headers, the mount make ot pissible to remove the oil filter, and the steering fits almost perfect between the trans and oil pan ..hope this helps..
  14. lorodz
    lorodz
    1 more thing if you buy their parts, they ship them fast, and you will receive your actual order, un like a company I won't mention their name... the guys at butchs are preety stand up guys. And again american made.
  15. gwayne
    gwayne
    hey tedster, KMA...Who asked your 2 cents? No one, go back in your hole..:rolleyes:
    my buddy ordered a set of shocks a while back, they arrived....just an fyi..
  16. Butch54
    Butch54
    from tree house
    thx for everyone's 2 cents... a comment was not helpful, just a dude spitting neg shit, you know who you are, must have had his old lady kick his ass today lmao
    looking at chris for the parts I need....
  17. ginuine555
    ginuine555
    from louisiana
    Do you need the information for Chris. He will open on July 1
  18. daddio211
    daddio211
    You're both new here, and I don't know how you misread Tedster's comment as anything but helpful, but he was just that. He's built an INCREDIBLE shoebox and is a wealth of shoebox info which he freely imparts. He did nothing wrong, just helping you know that Jamco has some SERIOUS issues. Yes, do a search here. Won't take you long to read hundreds of accounts.
  19. daddio211
    daddio211
