Saving a 32 Ford Body
Discussion in 'The Hokey Ass Message Board' started by rcnut223, Dec 11, 2011.
  1. I like the new body ya picked up....Looks great and should be a fun build.
  2. rcnut223
    rcnut223
    from wisconsin
    spent Sunday working on the rear exhaust.
  3. rcnut223
    rcnut223
    from wisconsin
    One of the issues that occurs with the bends is the tubes not lining up . In order to over come this you have to cut slits in the pipe and bend the pipe up and tack
  4. rcnut223
    rcnut223
    from wisconsin
    then you start welding...
    her is step by step...
    now for the grinding...but not today!
    kidcampbell71 likes this.
  5. rcnut223
    rcnut223
    from wisconsin
    Thanks for all the responses on the triangles.. I have what I need
    Thanks again Ron and Greg!!
  6. rcnut223
    rcnut223
    from wisconsin
    Well armed with patterns and an original tank, I started making the new triangles today.
    I decided to use 19 vs 18 gauge so that the metal would be easier to bend . first step was transferring the pattern to my sheet.
    once each was cut , in order to assure the same size i used clecos to hold them together filed them until they were dimensionally the same.
    when I marked the holes that go through the tank I was off a bit , so i used a washer positioned correctly and then used a die grinder to ream out the hole.
    Once bent I started the trial and error process until I was happy with the fit. Still needs a little work and final welding but here is the product. I'll have to trim the tank once the triangle is welded in place.
  7. big duece
    big duece
    from kansas
  8. rcnut223
    rcnut223
    from wisconsin
    Thanks for all your Help Greg (Big Duece)!!
  9. longgoner
    longgoner
    from western ny
    very nice! .... yist like enry's
  10. nailhead terry
    nailhead terry
    Man you are doing a great job Remember to many cats to few recipes cat the other white meat
  11. rcnut223
    rcnut223
    from wisconsin
    Longgoner - Ron, thanks for help as well!
  12. rcnut223
    rcnut223
    from wisconsin
    Started making the brackets for the exhaust a couple weeks ago..
    Cut these with a plasma cutter. I Used a sheet metal pattern with washers welded to the back for spacing.
    Ground the things smooth and drilled some holes for looks.
    The hangers were from Summit, thought they were kinda cool.
    Here's what the finished product looks like
  13. rcnut223
    rcnut223
    from wisconsin
    Here are some more shots of the exhaust.. not a lot of explanation needed.
    kidcampbell71 and mgtstumpy like this.
  14. rcnut223
    rcnut223
    from wisconsin
    same with this post posts. Finished some of the last few details on the exhaust , brake lines and the installed the park brake cables today. All that's left is the cutting the cable once adjusted.
    I shortened the exhaust , felt it looked better just behind the wheel
    Fuel lines remain, needed a brass fitting adapter for the fuel filter.
  15. ago
    ago
    from pgh. pa.
    Exhaust looks good, I use the same muffler connections, really like them.
    Ago
  16. rcnut223
    rcnut223
    from wisconsin
    I used a sleeve with these connections, concerned with leaks . Maybe I did not need these?
    Mike
  17. ago
    ago
    from pgh. pa.
    Some of those sleeves have a groove on one side of the face and a raised ring on the other. I use them and don't notice leaks. I have seen conventional slip over and clamp joint leak a little.
    Ago
  18. Outback
    Outback
    from NE Vic
    They are similar to some aviation ex-clamps I have used, I have wondered about their use on a car, aviation ones are quite expensive though..
    Nice work!
  19. rcnut223
    rcnut223
    from wisconsin
    These are called v-band clamps and are used on cars with turbo's . I welded a sleeve on one band half that slides inside the other band. covers the joint on the inside.
  20. Outback
    Outback
    from NE Vic
    Thanks,
    yeah, same clamps, cool!
  21. ago
    ago
    from pgh. pa.
    The 1st one I bought were from a guy selling older Indy car parts from Turbo engines. One thing nice about them is you can rotate, and they never seize in side each other from age and heat, come apart easy.
    Ago
  22. jfg455
    jfg455
    from NH
    You shouldn't have to do the sleeve. Just be very careful welding them on so they don't warp. If you do go with the sleeve make sure the open or unwelded end points down stream away from the exhaust flow. other way around would make it harder to seal.
    Build is looking sweet! Gives me ambition to invest WAY too much time into a 29 Essex coupe body that I have so I can improve my metal working skills (or lack there of...)
  23. rcnut223
    rcnut223
    from wisconsin
    well it's been awhile guys...but I have continued working just have not provided much for updates.
    Chassis has been torn down and prepped for paint here are some pictures.
  24. bartmcneill
    bartmcneill
    from Ada, OK
    I got a buddy in Seminole, OK that could build that body. I have seen him do amazing things with Model A coupe bodies. He has a rod shop on the south side. Name is Cliff Maxxon.
  25. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421507259.002785.jpg been busy working on the chopped coupe
    Will be updating progress over the next few days! ImageUploadedByH.A.M.B.1421507357.569617.jpg
  26. rcnut223
    rcnut223
    from wisconsin
    ImageUploadedByH.A.M.B.1421507487.750319.jpg ImageUploadedByH.A.M.B.1421507522.366588.jpg ImageUploadedByH.A.M.B.1421507546.667296.jpg ImageUploadedByH.A.M.B.1421507566.571698.jpg ImageUploadedByH.A.M.B.1421507594.484632.jpg ImageUploadedByH.A.M.B.1421507616.967456.jpg ImageUploadedByH.A.M.B.1421507649.483790.jpg ImageUploadedByH.A.M.B.1421507682.451037.jpg
  27. nunattax
    nunattax
    from IRELAND
    subscribed , good look on the build
  28. Angry Frenchman
    Angry Frenchman
  29. cavman
    cavman
    Hey Mike, good to see you back at it. I began to wonder where you were.
    They're lookin' good.
    Outback likes this.
