Sand-bending Exhaust Tube
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Sep 10, 2008.
  1. HOTTRODZZ
    HOTTRODZZ
    You crank through the length of your bend, ( it’s a good work out )
    You sneak up on your radius.
    You measure with a depth mike till you hit your target.
    THIS IS NOT a PRODUCTION MACHINE.
    It is a precession machine.
    Here are a few more pics.
    No drawings - But if you need a particular measurement or dimension, just ask.
    Hey - these pics give you 1000x more info than I started out with...LOL.
  2. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Very nice work! Now maybe I should start a roll bending thread to see what everyone else is using :rolleyes:
    Thanks!
  3. yoyodyne
    yoyodyne
    It appears that you vary the radius as you work to make the parts in those photos. Is it difficult to make 2 identical parts like that?
    Can you roll 2" X 120 wall 1020? 1.75 X 120?
  4. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  5. HOTTRODZZ
    HOTTRODZZ
    YoYo D -
    The reason I built this deal was to make identical sweeps.
    The DRO & the depth mike help you hit the desiered bend. ( trig - triangle formula )
    This is the 4th rev. of this bender - right now it will go up to 1.625 x .134
    More die blanks are cut & most of the cad is done for more range in dia. - I plan on going up to 4.0 x .125 -
    I will post more in The new roller thread tomarrow.
  6. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Arc Master radius gauges help repeat bends as well when roll bending. Digital readout is nice to have, but the same results can be achived without.
  7. HOTTRODZZ
    HOTTRODZZ
    Ok - Here are some test bends.
    In days gone by, I used play box sand - ok results - but never what I considered good.
    This time I used 120g silica carbide.
    I capped one side, filled - tapped - and pluged em up
    The amount the silica drops while tapping on ground is a - maze - in..!
    The samps are .058 wall 4130 - .065 wall 4130 - .083 wall 4130 - .125 wall DOM & .058 wall TI.
    All in all it worked out pretty good.
    The smaller dia 4130 bent real nice
    The thick wall DOM not so nice.
    Biggest Surprize Was the TI - Heat was only aplied to one side & bend was slow - but VERY nice smooth results.
    In summary - for short lenghts & slow sweeping arc's this is very do able.
    Lotsa work cappin & fillin - but not as much work as building dies.
    Would NOT want to do lengths longer than 3 feet.
    .125 + wall - bad idea.
    Any Q's - ask away.
    RMP
    kidcampbell71 and ScoobTEQ like this.
  8. HOTTRODZZ
    HOTTRODZZ
    More Pictures,
    kidcampbell71 likes this.
  9. cretin
    cretin
    I just tried sand bending last weekend. I just bent up a couple little things for my motorcycle. Nothing impressive, but the sand bending worked great. Granted it was only 3/4" tubing though.
  10. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Lookin good
  11. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I assume this is sand bent.
  12. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I have a ton of pics with what looks like sand bent exhaust from Road America last weekend.
  13. band instruments(trumpets, etc) were bent this way...now I believe they use ice
  14. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I think there was an episode of how its made on that.
  15. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Any more examples?
