Sand-bending Exhaust Tube
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Sep 10, 2008.
  1. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    kidcampbell71 likes this.
  2. oilslinger53
    oilslinger53
    from covina CA
    you can do it but the pipe has to be full all the way, and capped off at both ends or it will still kink, and just push the sand out the ends.i used to bend peices of tubink for lowrider bike fork that way when i was a wee lad
  3. MilesM
    MilesM
    Search Metalshapes posts for tech on how to do this.
  4. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I am just trying to understand it. I know you can bend tube by heating it, but can you actually bend headers that look descent this way? Anybody have any pics of headers bent this way?
  5. mottsrods
    mottsrods
    I used to make all of the headers for my rotary race engines. This is how I did it, and it works. I had to have the headers bent in a certain way, and I could do it this way quicker than buying a unversal header kit and welding it together. And it was cheaper.
  6. NOTCH
    NOTCH
    my buddy pat lash bent his exhaust with sand [​IMG]
  7. matts33
    matts33
    There was a video on You Tube some time ago where they filled the pipe with sand and water and taped off the ends. They then just used a cheap hydraulic pipe bender with good results.
  8. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    that is impressive
  9. Gusaroo
    Gusaroo
    I hear people do this all the time, my one reservation would be the "capping off" part. I would assume you don't completely seal the ends, if you did that and then heat up a muddy water mixture, you'd be making one hell of a pipe bomb!
    Hows that work?
  10. skunx1964
    skunx1964
    you cant heat it too much with water in it. ever held a lighter under a plastic cup with water in it? surprisingly it doesnt melt
  11. jusjunk
    jusjunk
    from Michigan
    never heard of the water stuff.. but ya fill it with sand but you need to pack it really good. then heat and bend.
    Dave
  12. Gusaroo
    Gusaroo
    can't sweat a wet pipe either
  13. skunx1964
    skunx1964
    i know all about that, sux. always hated doin repair calls on old copper plumbing
  14. fab32
    fab32
    Make ABSOLUTELY sure the sand is completely dry before you use it. Wet sand in an enclosed container is a BOMB when heated hot enough to bend the pipe.
    Frank
  15. NOTCH
    NOTCH
    I helped pat lash do his exhaust pipe's on his roadster. we welded up one side then packed tight with sand and I mean packed the shit out of it.. Then we ducted tape the other end up and NOT using any water in with the sand.. DRY SAND ONLY.. then we heated up a little section at a time over a woodin buck...
  16. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Did you bend the headers that way as well? Or just the large radius bend?
  17. NOTCH
    NOTCH
    just the large bends
  18. TGrant
    TGrant
    from Ohio
    Its more work than its worth. You have to dry the sand in an oven or the pipe will explode and like kill you.
    I know a guy that does it regularly and it scares the shit out of me even with sand that has been dryed.
  19. metalshapes
    metalshapes
  20. CoalTownKid
    CoalTownKid
    Lots of early hot rodders (pre-wwii) did this,....
    its been around for a long time....a forgotten art.
  21. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Doane Spencer did this type of bending for most of his headers, I helped him with a set he made for a Lola T600 and when he was done and had them chromed (Doane loved chrome) they were beautiful!!. Dry sand, cap the ends, absolutely tamp the shit out of the sand and use a big torch and lots of time. A guy, Kiwi I think, named Pete Wilkens made all of the Titanium headers for the original Ford four cam Indy motors this way and man they were neat.
    Rex
  22. Wildfire
    Wildfire
    I've got some square tube downstairs right now that is packed full of sand. Been playing around with it for a few months, works just fine.
    Your wife will shit when she comes home and finds the roasting pan full of sand in the oven. If she doesn't, you can tell her about the bellhousing you ran through the dishwasher (I suggest the pot scrubber cycle, btw)
  23. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    My wife would kill me. I get chewed for having sand in my shoes.
  24. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    post up some more pics please
  25. fiat gasser
    fiat gasser
    Jim Humes did a step by step article on sand bending for gasser wars magazine earlier this year. If you contacted them it's very informative. www.gasserwarsmagazine.com 360-568-1709
  26. temper_mental
    temper_mental
    from Texas
    I call bull shit on this statement .I forge tubing all the time with sand in it to hold the shape and also apply force with a trip hammer for texture .No explosions will happen .Maybe if you put gas in the sand it might explode .
    My 2 cents
  27. titus
    titus
    when i was like 12 or 13 years old me and my dad bent up a set of handle bars for a bicycle with he process of Sand-bending, we packed em full of sand and then welded caps on the end of the bars. it worked great
    i think the problem with the water in the sand is when it turns to steam it wants to get out.
    jeff
  28. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I would like to see some close ups of some bends that have been bent this way. Just curious how the bends look on a tight radius like headers.
  29. Ebbsspeed
    Ebbsspeed
    You CAN heat it too much with water in it! If you have any moisture in the sand at all, you absolutely CANNOT seal both ends of the pipe, you need to have somewhere for the steam to vent. Ever seen the aftermath of a boiler explosion? Ever see the Mythbusters episode with the hot water heater rocket? You heat a pipe full of water too much, that's what you've got, albeit on a smaller scale.
  30. stude_trucks
    stude_trucks
    Just drill a couple of very tiny holes in the ends to let the pressure of any steam or other vapors out and it won't be a problem. You can also just vibrate the sand instead of trying to pack it down. The vibrating probably will work way better and faster. That is what they do with concrete in formwork, they don't to pack it down, same principal. Just don't let your wife know that you did that with "that". :eek:
    Actually, you will probably need a vibrator stronger than that kind. Might be able to rent something or get an old elc. motor with an out of balance weight on the shaft or something or one one of those small deburring machines maybe.
