Technical Safe to assume?
Discussion in 'The Hokey Ass Message Board' started by bct, Jan 22, 2020.
  1. bct
    bct
    These manifold studs are all screw in? I can see one is. Foed flathead. Late 30s i think
  2. Screwed or pressed in, more likely screwed. If you are trying to replace them, heat will be your friend, but by the looks of it, they have already met the gas axe. 2 nuts locked together and cherry red heat should shift them if they have a thread.
    bct likes this.
  3. belair
    belair
    it is never safe to assume.
  4. bct
    bct
    On it . Using canadian stud removal liquid for heat cycleLol 15797281995123508293518266577146.jpg
  5. bct
    bct
    Last one broke. Drilled it to letter size M then melted the thin remaining threads away. Cleaned with an old tap.
  6. flatheadpete
    flatheadpete
    from Burton, MI
    That's working smart!!
    lothiandon1940 likes this.
  7. Fortunateson
    Fortunateson
    I heard that they have opened a plant up in Kitimat as well as St Johns to package that new invention... LOL
    lothiandon1940 and bct like this.
  8. BJR
    BJR
    Sounds like a snow job to me!:p
  9. Mr48chev
    I'm just really glad that it is you doing that rather than me. That is way way down on my favorite things to do chart probably on page five.
  10. bct
    bct
    Found new studs locally. Should i use neversieze? Or will the heat make it useless? Thanks.
  11. thunderbirdesq
    thunderbirdesq
    Most anti seize is rated for pretty extreme temps, 1200-1500 degrees or more. I use it to lube the kingpins while dropping axles. However... you don’t really want those studs threading in and out of the manifold, you want them to stay put. I’d use some high heat loc tite.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    By all means , use the anti-seize , that's what its for .!
    bct likes this.
  13. tubman
    tubman
    Also, use brass nuts on the studs when you install the exhaust pipes. If I remember correctly, they are typical Ford studs : coarse threads into the block and fine threads for the nuts.
    bct, Hnstray and Wanderlust like this.
  14. Wanderlust
    Wanderlust
    Brass nuts on exhaust is the cats ass
    bct likes this.
  15. 283john
    283john
    "Local studs seek to fill your holes"
    Flathead Dave and bct like this.
  16. tubman
    tubman
    I'd use the "Never-Seize". I have never heard of bolts or studs falling out because of it's use. Even if it does no good at all (which I do NOT believe), you would be no worse off than if you didn't use it.
    I love "Never-Seize" (except for the mess it makes if you're not super careful).:D
    bct likes this.
  17. bct
    bct
    Yes mix of 7/16" course in the manifold and fine . Thanks for the info everyone.
  18. Flathead Dave
    Flathead Dave
    from So. Cal.
  19. thunderbirdesq
    thunderbirdesq
    I didn’t say they would fall out I said you don’t want them to come out after they’re installed, you want the stud to stay put and the nut to come off. If they were intended to thread in and out of the manifold they would be a bolt not a stud.
