Vintage Metalworks T5 adapter for the 4x4 S10. I have decided to go open drive so I no longer need this. It is a beautifully machined piece. It has only been bench bolted to a transmission and then removed. The mating surface was marred a little while removing it from the trans, but that in no way affects the functionality and barely the appearance once mounted. David machines his own trans yoke which mates to an early for driveshaft yoke. This is a complete setup with adapter and yokes. This is for a 6 spline driveshaft. $650 shipped to the lower 48.
Bump. I have the transmission that you need to run this adapter for sale also. Let's make a deal. https://www.jalopyjournal.com/forum/threads/s10-t5-4x4-rebuilt.1111273/#post-12736574
