My version of the T5 shifter. Turned a Cheap Egay T5 shifter designed for the Mustang in the lathe. Coulda just redrilled the holes but that be ghetto. Made a new base and cannabalized the mustang shifter for parts . Works flawless and for $26 delivered....I'm pretty happy.
Nice! I did the ghetto version with a used Pro 5 off of ebay. Have 50 bucks in mine... it's money well spent.
You can just buy a short throw shifter for the S10 T5, but it's not that cheap (surprise). If you don't have the time, skill or tools to make what you did it can be bought. That said you ended up with a nice looking piece. I like the corner detail for the fasteners. And the available shifters don't have the positive stops you kept from the Mustang donor shifter. A real nice feature to retain.
That’s pretty rad!!! Turned out nice! Call me Joe Dirt if you want, I did it this way, it was free and I built it with what I had... http://www.waywardgarage.com/tech/t5shifter/t5shifter.html
Not so sure that is still the case. A few months ago I was looking for a short throw S-10 shifter and could not find anything new in the market. Maybe I missed something, but I think I looked reasonably thoroughly. A fellow HAMBER saw a post where I mentioned that and contacted me about an NOS B&M unit that he had purchased years ago but did not use. They have been out of production, and stock, for years. Bought it and glad to have gotten it. Hats off to the posters who reworked non-S10 units! Ray
I think Core is still making the S10 shifters, but I have not shopped in a while. They were $2-300 bucks, which is a lot more than I paid for my transmission, so it was no bueno for my build. A decent amount of bay stalking will turn up Mustang shifters that are better than the $26 China ones, for not much more money. I used a Pro-5 because it was "flat" topped, which makes the mods a bit easier.
Nice work on the shifter! I made one following el Scotto's link out of 1" thick 6061 aluminum plate donated from a friendly scrapper. I only moved the pin up 1", the thickness of the plate, not sure why Scotto moved the pin 1" but made a 1 1/4" plate. Oh well, finding a 1/4" plate will be easier if needed to add thickness.
Core (as mentioned) https://core-shifters.com/collectio...s10-s15-t5-5-speed-3910033?variant=8897177987 And Hurst https://www.summitracing.com/parts/huu-3916045/overview/
Some body 'skool me' on this good looking mod!The round outer portion is 1 1/2 in. tall? Is the shift lever also extended 1 1/2" ?(NOT the shifter!) Exactly how does this make it a shorter throw? Is the pivoting point moved up 1 1/2' also? I really like the shift stops you put in. I understand that's a weak point in T-5's, I have one of those ......"un-mentionables, with a capital M..." that would really benefit from one of these. Just trying to understand the physics of how it improves whats stock. Thanx 6sally6
It's all about pivot points https://www.musclecardiy.com/transmissions/manual-transmission-shifter-basics/
Looks nice. My first try was like this one, modified Mustang cheap shifter. I just re drilled and counter-bored the holes on my mill and it worked great, for a cheap shifter, but it was sloppy. I ended up modifying the stock unit by welding in a 1" section to the stock shifter tower and drilling a new hole 1" up. it works OK, but the spring is weak and does not return to neutral like I think it should. I also welded nuts to the tower to make my own positive stops.
Sally, As Stumpy posted.....it's all about raising the fulcrum. The shifter was designed by "others". I didn't change the fulcrum height, just adapted it to the S10 shifter box. The top pic is as it came from Egay. Flt, The cheap shifters add additional springs under the fulcrum stub on both sides for aiding the "neutral return" which also incorporate adjustable side throw stops. The stock shifter had a nylon spider looking thing that fitted above the fulcrum. I added this to the cheapy making the shifter stalk somewhat "encased" in nylon. Not sure of the durability of the shifter though. Time will tell. While I was at it I replaced the nylon shifter cup with a brass one.
I had not ran across this page... good info. My modified shifter is similar to the early Mustang version. I also note the pricing is different than I remembered. Buying just the bases makes these a better deal for us roll your own shift rod types than the full package Core units I looked at.
