Hello you all knuckle busters enthusiast, quick question, Just picked up a 1992 S10 rear end for the 48 Fleetmaster, and I was wondering if it would be possible to go ahead and use the whole brake system out of the S10? front discs calipers, master cylinder.... etc. or as always, has anyone done something similar? besides the standard kits out there. thanks in advance Jorge
Sure you can, but only if you graft in the entire S-10 sub-frame! (just joking, we don't do that kind of nonsense around here) My recommendation is to check out the Stovebolt forums on the internet, there's lots of information on options when it comes to suspension upgrades.
You can use the booster and the master cylinder and the front calipers. Right off I am not finding kits for the "Metric" front calipers or rotors. Most of the kits like this one use the mid 70's Camaro/73/77 Chevelle Rotors and calipers Chevy Parts » Brake Disc Conversion Front - 41-48 Knee Action. Basic Kit (No Rotors/ (chevsofthe40s.com)
Subframe grafts are obsolete 80's tech from the days when we didn't have anything better to use but just don't fly in the real world now.
I'd compare spindle from the S-10 to the spindle on the 48 Fleetmaster and see if they have any similarities in mounting. Might take a picture of each of them and post them. Its doubtful that they can be adapted easily, but need more info. Also, how does the S10 tread width compare to the Fleetmaster tread width. There is almost always a way to make things work but it may be easier to buy a readymade conversion for the front wheels and then use the rest of the components with that.
On my Studebaker truck I used all the components, for a 75 manual disc/drum Camaro and the truck is a little lighter than the Camaro and the brakes work like they should. The only oddball piece was the brake pedal and I used a hanging one from Speedway.
Every now and again I read something and think, yea... I remember when I'd agree with that. But I don't have the luxury anymore to think so. Aside from the speed of which the cash for clunker programs cleaned the countryside of dead 74 -78 Mustangs, Pinto, Volaries, Nova and Camaro clips, manufacturing and design change into unibody construction meant less transferable selection and an aftermarket parts to fill the void industry was born. Time and place, I guess?
All of those were too old to qualify for "Cash for Clunkers". Price of scrap metal was high and a lot of older cars were "recycled".
More searching shows that the kits to bolt disk brakes on 41/48 Chevy car spindles use the 73/77 Camaro rotors and calipers. They are pretty inexpensive to buy new. but the kit isn't real cheap for just the brackets, bearing spacer and bolts.
Spindles on the late 40's Chev cars are closer to I beam axle spindles with kingpins. No way they'll be close to an S10. It will require a special custom mounting kit just to be able to use the calippers, and then who knows if the S10 rotors could be fitted in any way to the large old Chevy spindles.
