Running new brake lines
Discussion in 'The Hokey Ass Message Board' started by dirtbag63, Dec 7, 2011.
  1. dirtbag63
    dirtbag63
    Just installed a dual master cylinder on my 54 Bel Air. I noticed that there are two different size brake lines under my car, not sure why. Should I do any modification since I am going to a dual set up, or just use the existing lines? Thanks,
    Dirtbag63
  2. 54fierro
    54fierro
    from san diego
    It would be a good idea to replace them as they are going on 60 yrs old. Stock is 3/16 to the front and 1/4 to the rear, but if i were redoing everything i would run 3/16 the whole way. Cesar
  3. When in doubt, throw it out. Most anything newer is plumbed in 3/16 from what I've seen. If the lines look clean and not rusted, then you have a judgement call on whether to replace them.
    Bob
  4. metalix_421
    metalix_421
    just take a look at them, my 56 looks good and plan to run the 55 year old lines but like said above use your best judgement.
  5. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    I have mixed sizes on both of my cars. Seems to work fine...
  6. Dane
    Dane
    from Soquel, CA
    I never trust 50+ year old brake line.
    Here is the best line I've ever used. It's a copper-nickel 90-10 and looks great on old cars. Best part is it's easy to double flare, even with the cheapo flare tools.
    http://store.fedhillusa.com/cnf3a.aspx
  7. deeddude
    deeddude
    I'm currently doing the same. I'm replacing the lines with 3/16". Should be fine. I did this on a few stock cars and they all worked great. The last one I did I use a corvette master for disk all around, stops fine. I should finish the 54's brakes this weekend,I used a master from a 67 camaro for drums. I'll let you know how it works out.
  8. 40FordGuy
    40FordGuy
    Old steel ,...rust,.... Just put in all new,...Safer that way .
    4TTRUK
  9. Cruiser
    Cruiser
    Since it's your life, new lines are the only way to go in this case.
    CRUISER :cool:
  10. Doctor Detroit
    Doctor Detroit
    Check out Poly-Armour Steel lines or NiCopp brake lines. Available at NAPA. The Poly-Armour is priced pretty reasonably. I've been researching this because I'm about ready to run new lines on mine. They come in straight lengths of 8", 12", 20", 30", 40", 51", 60", (and some 72" or 84"). They also have the fittings installed on both ends, and you can bend them by hand, or the $15 Speedway bender.
    http://www.agscompany.com/faq
    http://www.agscompany.com/automotive/brake-fuel-transmission-lines/poly-armour
    http://www.agscompany.com/automotive/brake-fuel-transmission-lines/nicopp
  11. ArtofHotRod
    ArtofHotRod
    A shot of the new lines on my 54 Chevy
  12. alicia-dusty
    alicia-dusty
    It's not always just age I just replaced 2 lines on my '98 dodge pu. Don't cheap on brakes or steering. And brake lines are cheap.
    and
