Technical Rumble lid to trunk lid conversion 32 five window
Discussion in 'Traditional Hot Rods' started by koolbeans, May 25, 2019.
  1. koolbeans
    koolbeans
    Sure would be helpful to have some pics of the pieces needed and the actual install of the conversion.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  2. Dak Rat
    Dak Rat
    from NoDak
    Covered quite a bit over on the Ford Barn. People there have done it, and know what it takes.
  3. Hamtown Al likes this.
  4. Buy the kit drill hole in deck lid. Fill the other. Add rubber bumpers. Install catch
  5. oldbanger71
    oldbanger71
    Hey koolbeans, i made the conversion from trunk to rumble. Unfortunatley we live not closer, we could swap Parts.
    You will need the strikeranel where the latch is mounted. Latch, hinges and lidsupport. Drill the holes.... bolt together, you may need to shirt the hinges to fit nice......and your done.
    If you need i can send you pics tonight.
    kidcampbell71 likes this.
  6. koolbeans
    koolbeans
    Pics would be helpful. Thanks
  7. oldbanger71
    oldbanger71
    Koolbeans, i didn't take pics, from bevore conversion from trunklid installation , but for now here is the latch-panel that was bolted in.
    When i go to the shop today i will take pics from the hinges, handle and lid.
    If you post some pics of your Lid i can tell what is missing on yours. Latch panel.png
  8. oldbanger71
    oldbanger71
    Here a sideview where the hinges where fixed to the trunklid and below the corresponding hole and fixingscrews.
    I made the bracket on the lid for the 3 Window rumblelatch , so this is not needed for the trunk. The rubber bumper is moved to the trunklatch panel on the rear.
  9. koolbeans
    koolbeans
    Yours are best pics. Have I hope the parts coming. Will keep you posted.
    Few up dates...pedals, rockers for rear coilovers, front end scaled, wood patterns for flooring...plugging away..jim IMG_20190603_130954208.jpeg IMG_20190603_130923528.jpeg IMG_20190601_135425282.jpeg IMG_20190529_121456616.jpeg IMG_20190527_123424763.jpeg
  10. oliver westlund
    oliver westlund
    rumble seats are cooler, you can literally bring your buddies to the rumble! they sit over the rumble of your exhaust! idk, i always get excited when i see the handle at the top and the step pads
    clem likes this.
  11. oldbanger71
    oldbanger71
    @ Jim, your progess is fast and looks good, nice enineering on the coilovers, thanks for sharing.
    My plywood boards are rubbing and squeaking, give them enough air and something between to glide......
    just my two cents, but i'm sure you concidered that alredy.
    @ Oliver: No handle, no steppad, but old boat seat as rumble very spartanic and low weight. took this pic last week, no Photoshop but old camera with film b/w. This way you can't tell when the rumble is closed.
    clem and oliver westlund like this.
  12. koolbeans
    koolbeans
    Oldbanger71, missed this .... brain fried...good thought on anti squeek...rekon there are gonna be lots of squeeks...back in the day used 3M strip seal between panels and floor joints for sealing and cushion. Trick to working the stuff was to put it in the refrigerator...it hardens up, you can split it easy with razor into smaller strips, and with it firm it applies lots easier. IMG_20190704_093415082.jpeg IMG_20190706_090008687.jpeg IMG_20190704_093341356.jpeg
