Rpu, is water pipe traditional?
Discussion in 'The Hokey Ass Message Board' started by fine29, Sep 16, 2014.
  1. fine29
    fine29
    from Des Moines
    We just picked up this rpu last weekend and boy is the work on this thing scary haha. They used water pipe for the ends of the 4 bar, and the welds in this thing are beyond questionable. There isn't even any suspension travel.. They just set the frame all the way down and bolted the coil overs on. ImageUploadedByH.A.M.B.1410909674.291392.jpg ImageUploadedByH.A.M.B.1410909694.707315.jpg ImageUploadedByH.A.M.B.1410909709.190924.jpg ImageUploadedByH.A.M.B.1410909719.974130.jpg ImageUploadedByH.A.M.B.1410909739.723818.jpg ImageUploadedByH.A.M.B.1410909749.591274.jpg ImageUploadedByH.A.M.B.1410909770.257169.jpg
  2. Ummm....yikes!!!!
  3. Ulu
    Ulu
    from CenCal
    Traditional?
    OMG no!
  4. GTS225
    GTS225
    First, I'll agree with you....it looks like scary ass. Second, I would argue that water pipe is "traditional". Safe?, NO, but traditional, yes. Before there were standards of auto construction safety, I'm reasonably sure that folks built, repaired, or modified cars with whatever they had laying around. If it was water pipe or angle iron, so be it. We've come a long ways since then, but depending how far back one goes in the timeline, then yes, it's traditional.
    Either way, correct the problems, and don't forget to post progress.
    Roger
    volvobrynk likes this.
  5. are those traditional booger welds?
  6. Ulu
    Ulu
    from CenCal
    Rust Flavored Gummy Welds.
  7. motoandy
    motoandy
    from MB, SC
    death trap. That is scary.
  8. Well, galvanized is better than copper.
  9. Well, at least you don't have to have any qualms about tearing it all apart and starting over. Nothing mechanical is worth saving so might as well do it all from the ground up.
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
    The chipboard flooring (non weatherproof) isn't traditional.:cool:
    That's a RR how not to;
    No grade 8 hardware on the suspension (or lock washers/nuts).
    Horrific welds
    No e brake.
    Hope you didn't pay much for the "vehicle". Glad it's off the road as it's a death trap.
    How's the body? I hope the same guy didn't do the body work...
  11. Kiwi 4d
    Kiwi 4d
    The only good thing is the blobby welds appear fresh so hopefully it hasn't been heading towards you on the highway.
    so what does the body look like.?
  12. Easy fix,,throw all the carp away and build it right. HRP
    NWGreaser and volvobrynk like this.
  13. LongT
    LongT
    I bought a 60 Corvette with a straight axle in 1967. The axle and the ends were water pipe!
    surfgeezer likes this.
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    That is about as crappy as I have ever seen ! WOW ! In the 60's I bought a 34 Ford roadster and they had used water pipe for the rear radius rods and had simply hammered the front end of the bars flat and drilled a hole through that part for a bolt to pass through. Even though I was only 16 I knew that wasn't right.
    This is proof not everyone should be building cars.
    Don
  15. no.scar.no.story
    no.scar.no.story
    Whoa... yep. Scary.
  16. fine29
    fine29
    from Des Moines
    the body is actually solid and an original 29 not a repop has a little filler but once we have the chassis straightened out the body will be stripped and done correctly.
  17. skidmarks
    skidmarks
    from USA
    that thing is rad, any pictures of the rest of the truck?
  18. Ok, since you see you'll be starting from scratch why would you even buy that thing?
    Just start from scratch and save the trouble
    Muttley likes this.
  19. 296ardun
    296ardun
    Yes, unfortunatly water pipe was traditional...some guys built roll bars out of it, imagine how well that would have held up....all the above comments are spot on, glad you asked...
  20. How about a pic of the rest of the car?
  21. fine29
    fine29
    from Des Moines
    it was my grandpas deal he wanted it. I knew it needed some welding done but I didnt realize the extent of it until we got it home and in the air.
  22. Rattle Trap
    Rattle Trap
    OMG! Pull the body and drive train and roll the rest to the scrap yard.
  23. fine29
    fine29
    from Des Moines
    ImageUploadedByH.A.M.B.1410924984.687414.jpg ImageUploadedByH.A.M.B.1410925002.071415.jpg ImageUploadedByH.A.M.B.1410925014.587423.jpg needs different wheels and tires but that will come after everything else is fixed.
    Hotrodmyk likes this.
  24. 55willys
    55willys
    Looks good body wise but time to go backward on the frame to go forward with your project. Jim
  25. Slopok
    Slopok
    I remember seeing roll bars made out of exhaust pipe and front & side bracing made from fence pipe in early sportsman stock cars at Santa Fe Speedway. It's a miracle many of us are here today. When you're young you're tuff.
    fine29 likes this.
  26. If the broken welds don't kill you - welding on galvanized pipe sure will
  27. Muttley
    Muttley
    Ray Charles could have done better work than that.
  28. Beautiful craftsmanship , I'm guessing the builder was blind?
  29. loudbang
    I didn't see any fish in it???? :rolleyes:
    primeisnotacrime likes this.
  30. mgtstumpy
    mgtstumpy
    WTF, that's why the authorities down here in conjunction with rodders invented rules that we must comply with to get registration. Safety, engineering and build quality are not considered optional but mandatory.
