Technical Roding out radiator ?
Discussion in 'The Hokey Ass Message Board' started by BRAD5OCAD, Nov 1, 2014.
  1. BRAD5OCAD
    BRAD5OCAD
    from San Diego
    Ok this is my first post so I apologize if I'm missing anything my name is brad I have a 1950 Cadillac series 62 I recently pulled the water pump off to rebuild and figured I would remove the radiator to clean it up and pressure test it well it leaks all over and the brackets broke off with no effort after I took layers of paint off the brazing looked like a child did it I figured since I can braze (I do a lot in the navy I might as well disassemble it and rod it out I've never done this so any help would be grateful some pics of the radiator
  2. manyolcars
    manyolcars
    its not brass.Its solder
  3. In order to rod it out you have to remove the top and bottom tanks which means a lot of heat all around. The tanks will probably warp a little making it a little tricky to reassemble. Someone else probably tried it at home, hence the leaks.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    My Dad owned a radiator shop in the 50's and he rodded out many radiators, but it isn't as easy as it sounds. You have to remove at least the top tank, run appropriately sized flat pieces of steel down through each tube, and knock the buildup out of them. Then you have to resolder the tank back on, all around the perimeter, and not get any leaks.
    I used to watch him doing it and he would get it all soldered, put it down into a tank of water with air pressure going to the radiator, and bubbles would come out of some spots. So he would try to fix those spots but the process would sometimes open up new leaks. It was a very tough job, even with the correct equipment.
    Do yourself a favor, take it to a radiator shop and spend a few bucks to have it done right. I don't even think they rod out radiators anymore, but rather, they soak them in a hot caustic solution, then pressure wash the insides. If it is as bad as you describe it might even need a new core. This ain't for the faint of heart to try.
    Don
    SanDiegoHighwayman likes this.
  5. krazee
    krazee
    Rodding the rad is relatively easy but getting to that stage is the trick. It's best to take both tanks off by melting the solder, then using some recoil spring wire (Briggs & Stratton) with the end rounded "rod" each tube. Hose out the rad making sure each tube has a good flow, clean out the tanks and re solder
    the tanks back on, don't over do the solder. If it has been brazed it may pay to take it to a radiator specialist, you need to get all the bronze off. It takes me roughly 1 1/2 hrs to do a rad that size and that includes pressure testing, painting and maybe sealing a rotten tube. If someone has already "played" with the rad and made a mess I add 1/2hr. I also add an extra half hour if they want to watch and ask questions
  6. Take it to a old radiator shop that's been around for a long time and let them do it. HRP
  7. BRAD5OCAD
    BRAD5OCAD
    from San Diego
    Thanks for advice guys this radiator has had a lot of repairs over the years but it's original and I think it is repairable I think I'm going to find a radiator shop around los angles that will rod it out for me
  8. cvstl
    cvstl
    from StL MO
    1. H.A.M.B. Chapel
    If you can braze pretty well, it should be no big deal. Just melt the solder out and pull the tanks off. Rodding it out is relatively easy with some sheetmetal strips - the Briggs & Stratton recoil spring is a great idea - run them up and down the tubes until they are clear, being careful with any that may be bent or dented.
    Once water runs through freely, get the mating surfaces all cleaned up and re-solder it. Its not that hard if you get it all to fit right and clean acid flux and solder it up.
  9. need louvers ?
    need louvers ?
    Yup, absolutely no big deal until you put the tank back on with too much heat and realize that you have melted all the solder out of the header to tube joints. Then stuff gets real fun real real quick! The other thing too is there is a very specific way that the top tank is soldered on. Most see the fillet on the out side of solder and just try to go back in and re-fill... Bad! It needs to be securely soldered down in both the inside and outside of the u-shaped channel. The fillet is just the mostly cosmetic finish. Worked in a BUSY commercial radiator shop for three years as a kid in the eighties and did this stuff all day long... Now I wouldn't try it, especially without the right tools!
  10. BRAD5OCAD
    BRAD5OCAD
    from San Diego
    Well I have a weld shop at my disposal I am the only ht at my command but I trust need louvers he seems like a technical expert and he wouldn't do it so I'll leave it to a pro anyone know of a radiator shop in so-cal that rods out radiators still
  11. walker
    walker
    Been there, tried that, it sucks. Cheaper to have it done by a pro.
  12. cvstl
    cvstl
    from StL MO
    1. H.A.M.B. Chapel
    Good points Mr. Louvers. I have done it a couple of times with no issues, but I may have just been lucky..... and come to think of it, it was back in the mid eighties when I was a kid.... I'd probably still try it again myself, but then again, if I could find a good shop, maybe not.
  13. SanDiegoHighwayman
    SanDiegoHighwayman
  14. samurai mike
    samurai mike
    old guy at a local rad shop used a dip stick to rod out radiators
  15. BRAD5OCAD
    BRAD5OCAD
    from San Diego
    Sweet I work right across the bridge I'll take it next week thanks
  16. SanDiegoHighwayman
    SanDiegoHighwayman
    yer welcome :) When you git it back it will be just like NEW both in looks and function
  17. Don's Hot Rods
    Don's Hot Rods
    from florida
    We have an old time radiator shop here in town that I have used for years. The last time I took a radiator in the guy who worked there brought it over to me and I asked if he did the work, and he said yes. So I gave him a tip. When I went into the office to pay the boss said "You don't owe me anything, you already took care of my man." :eek: I tried to argue, but he said that I had paid enough already. You don't see that every day, and why I keep going back to them ! I love these businesses that have been around for years and years.........they know how to conduct business.
    Don
    Phillips and SanDiegoHighwayman like this.
