Trunk lid handle, new, chrome, tear drop shape, very Art Deco, has lock cylinder and two keys. Has square shaft and will work with most old Ford trunk latches and others. You've seen these available from Limeworks for $80 plus shipping. SOLD This seat cover is the perfect look for a nostalgia car. This is a vintage aftermarket seat cover that has been reshaped to fit a seat small enough for most 1928 to 1934 Ford and other hot rods of similar size, was specifically fitted to a 32 coupe seat. It is shown here fitted to a Dodge Caravan, Plymouth Voyager middle seat (seat not included, just cover). It will take a small amount of additional padding to fit with a perfect shape, but then that's really necessary with any installation of these seats in an early Ford in order for it to look "right". The colors and pattern are the perfect touch for a traditional hotrod. By the time you find a good original vintage seat cover, and then have the cover modified for fit by a professional upholsterer, you can't touch it for my price. $295 shipped to lower 48 A pair of NOS 32 perch pins. These have never been used except for brief mock up, new, so no rust pitting, new shackle bushings, good shock dog bone pivots, and excellent threads on the bottoms. No questionable import junk copies made in China. $200 the pair shipped lower 48 Chassis Engineering motor mount kit to install a small block Chevrolet in a 1935, 1936, 1937, 1938, 1939, or 1940 Ford, p/n CP-2101. This is a complete bolt in set of mounts for the engine, but could be welded as well. New, never been installed, only taken out of package to photo. SOLD Halibrand style quick release Indy race car style fuel cap and sunken surround piece. These are "reproductions" from Crafty B. The locking bar on top does a nice job of sealing the unit against the O-ring seal underneath. Look at pictures to see how the pieces separate for different applications. These pieces have both smooth machined surfaces, and rough cast so that you have choices for the finish you want. Also comes with a length of gasoline proof hose, 1 3/4" ID (can be heated and stretched a bit) , to connect to your tank.SOLD Steering arm, Super Bell, new, only used for mock up. This mounts to the driver side spindle if you are using a side steer drag link, tapered hole for Ford tie rod. SOLD Yankee 332 license plate light, new in box. This is an old stock part, not some reproduction. The chrome shines like new, though to the finger there is something on the surface not visible to my old eyes that can be felt. SOLD Hollywood style license plate light and bracket, stainless steel reproduction still in bubble pack. SOLD View attachment 2852436
