I've got this old Fenton 2x2 intake for my 1953 Rocket Olds engine. It comes standard with three holes (don't know the right word for it...). I quess the hole near the waterneck is for the temperature sender, but I can't figure out what the other two holes are for. Do you guys have any ideas??
That's what I would say. #1 is heat for the auto choke dashpot, and # 2 a vacum port for advance and windshield wipers when the mainfold was new.
Hole #2 is probably for the heater hose on the 303 that ran along the left side of the block to the firewall. Pic attached of a stock setup that might be some help. Oops, I see that #2 is indeed in an intake runner. Definitely nothing to do with water! My bad.
Hole #1 is for brake vacume Hole #2 someone added ...not factory ???? you wouldn't use this for anything but vac advance as it is a intake runner only If it were me I would tee vac port in "box" area if I was running brakes and wipers Tony Ross Racing Engines Niles,Ohio 330-544-4466
Not for long, they don't. I don't know if all Olds and buicks had the dual function fuel pump or if it was an option.
