Technical Roadster inner frame
Discussion in 'Traditional Hot Rods' started by terry k, Oct 5, 2019.
  1. terry k
    terry k
    from toledo oh
    I thought I remember that someone manufactured a steel frame to install in a steel '32 roadster body behind the seat area. Anyone know who that was ? Thanks Terry
  2. treb11
    treb11
    Steadfast makes a set for putting a Model A body on a '32 frame. Is that what you were thinking of? Of course Brookfield makes the standard replacement parts.
    pitman likes this.
  3. Bam.inc
    Bam.inc
    from Salina, KS
  4. Bam.inc
    Bam.inc
    from Salina, KS
    & for H.A.M.B. Alliance members :
    Steadfast Mfg. – Famous for their model-a subrails, Steadfast is also responsible for all kinds of other fabrication. Check them out and take warmth in your 5% discount on select items!
  5. terry k
    terry k
    from toledo oh
    I'm talking about a steel tubing structure that adds some strength and safety to the stock steel body. Usually it would give you a location to mount safety belts etc.
  6. New Age Motorsports builds a nice tubular structure for their glass five window. Hope it provides some ideas for your roadster. tapatalk_1570371890253.jpeg tapatalk_1570371898342.jpeg tapatalk_1570371914544.jpeg
    Phil
  7. el Scotto
    el Scotto
    from Tracy, CA
    That Ionia Hot Rod shop setup looks killer!
    I’ll be watching this thread, I’m sure some good things have been done to deuces!
  8. terry k
    terry k
    from toledo oh
    Not trying to be lazy, but do to health reasons I was looking for a premade unit. I'll try Ionia shop. Thanks......
  9. Besty34
    Besty34
    from U k
    This is what I made for my 34, hope this helps
    alanp561 likes this.
  10. MoOctane
    MoOctane
    from Rolla Mo
    IMG_5301.JPG Kilbourn Rod Shop in Illinois uses this in their fiber glass bodies. 1x1 box tubing.
  11. terry k
    terry k
    from toledo oh
    Any suppliers ?
  12. Atwater Mike
    Atwater Mike
    The 'bends' in the square tubing are the key. Can they be done easily? (for you)
    If so, the fabrication is a breeze. If no wire welder, a 110 volt 150 amp welder will do it.
    Hopefully, you can find a mfr. with the pre-fitted inner frame. But it looks 'iffy'...
  13. cornfieldcustoms
    cornfieldcustoms
    we dont offer a pre made kit but we could make you one. we would just need the car or your measurements.
    kidcampbell71 and bct like this.
  14. terry k
    terry k
    from toledo oh
    Can't believe someone doesn't make one for the roadsters.
