Hot Rods Roadster build.
Discussion in 'The Hokey Ass Message Board' started by bct, Oct 21, 2015.
  1. bct
    bct
    Thanks f-head.
    I'll keep an eye out for gen. Makes sense that it would have a better bearing system to carry fan.
    If i need your fan ill pm you.
  2. Duke
    Duke
    I just measured a 32 shell for you, 20"- I think your rad will fit. If your coming to Vernon, bring the rad and we can try it for fit.
    bct likes this.
  3. dumprat
    dumprat
    from b.c.
    And KMS had repo shells on cheapish last time I was there.
    bct likes this.
  4. bct
    bct
    Thanks . Going to fit the rad i have and hope for the best. Its too wide for the mounts so i will move it ahead and solve two problems at once.
  5. bct
    bct
    A friend gave me the two volumes of machine shop practice. Improving as i go.
    Spacers fit perfect
    No gaskets yet but lots of room
    kidcampbell71 and patmanta like this.
  6. bct
    bct
    Did the mechanical early ford brakes use a grease baffle that i can use on my new backing plates? Or just adapt the hydraulic baffles ? Thanks
  7. dumprat
    dumprat
    from b.c.
    I have both types ya want em? I thrown them away and use real rubber seals instead of the leather crap. They used grease baffles because the seals didn't seal.
  8. bct
    bct
    Maybe. I have plenty of hydraulic ones . I have a 36 axle in the boneyard that im going to use the bolts and castlated nuts for this project. If the baffles are there then im good. If not i will take you up. While i was researching i noticed 8 fasteners in the pics of the mechanical baffles. Are the riveted on aswellas bolted?
  9. bct
    bct
    here is the pic?
  10. dumprat
    dumprat
    from b.c.
    Mine are all just held on with four bolts. I have two or three sets of them. You running mech brakes?
    bct likes this.
  11. bct
    bct
    No . Early spindles. Adapted to hyd.
  12. Seems to me, if I remember right, the earlier shields get into the bottom of the wheel cylinder.
    While I agree that modern seals are better and negate the need for the shields, I like to use them since they are part of Henry's original set-up.
    bct likes this.
  13. bct
    bct
    Thanks rich. Good to know.
  14. bct
    bct
    the early round fit just fine . the four smaller 3/8 bolts are nice to work with in the large grease shields. no bending needed
  15. bct
    bct
    I started with 5.5 x48" bent channel .125" material . cost $40 for the two pieces. if you can buy longer go for it . all the measurement start at the long point (bottom end facing K member).
  16. bct
    bct
    next is making a gusset at the u joint to join the legs and tie it all together . I will be riveting the legs to the frame and bolting to the kmember
    chop job, kidcampbell71 and RICH B like this.
  17. bct
    bct
    a little vid to help. the passenger side is a mirror image.
  18. Duke
    Duke
    Looks good!
    bct likes this.
  19. bct
    bct
    Model A front spring to 33/34 shackles ? What did you do? Stock ford parts or neat looking aftermarket.
  20. dumprat
    dumprat
    from b.c.
    .? I used cheap stainless aftermarket shackles. From 34 stock spring to stock perches.
  21. I used some NORS Model "A" shackles and bronze bushings.
  22. bct
    bct
    Model A spring has a smaller eye than the 32/34. I need to adapt the two sizes with an odd ball shackle. I have really nice 34 shackles that fully disassemble and was hoping to replace one end with model A or something. I know most model A are 1 piece but was looking for input on an alternative. .?
  23. bct
    bct
    So you pressed a bushing into the perch or machined new ones? Id imagine you would have a hard time pressing in a bushing with a 1/32" wall thickness without some kind of mandrel. Thanks
    flightt likes this.
  24. dumprat
    dumprat
    from b.c.
    If you are going to try and stay with all original stuff running a 34 main leaf might be the easiest option.
    Or like I said run some cheap chrome shackles and just skim the od of the bushing.
  25. I seem to recall @Chris did this in one of his threads. Maybe he'll see this and chime in if it was him.
    bct likes this.
  26. bct
    bct
    had to enlarge the m\c relief
    made a pattern for below my new legs. .25"
    more patterns
    machined some extensions for the 33\34 wbs
    smaller adapter on 33\34 spindle
    kidcampbell71 likes this.
  27. bct
    bct
    made spring spreader attachments for my simplex. I hope there is enough clearance on certain axles
    chop job likes this.
  28. bct
    bct
    spent the time I had this w\e to set up a used rotisserie I bought. had to fab a missing part but a good deal.
    pushed myself past midnight Saturday to build something fun . spreader bar.
  29. HotRodMicky
    HotRodMicky
    Hi great build !!!
    what size Rivet gun do you have?
    Micky
  30. bct
    bct
    Its a 4x. I ordered 5/16" rivets and round head setting tool for the frame legs. Im certain that the gun will handle them. Thanks
