Projects Road to Redemption: 49 Chevy Coupe Build
Discussion in 'The Hokey Ass Message Board' started by deto, Sep 11, 2014.
  1. deto
    deto
    Pics of the progress
    kiwijeff and daddio211 like this.
  2. deto
    deto
    Clutch fork modified. Making the mounts for the slave today
    kiwijeff, cretin and slammed like this.
  3. deto
    deto
    Faced the block side of the bell, fixed the cut out part of the flange, painted everything and bolted it back up...
  4. Great progress. Can you get a close up of the slave & fork? I'm going down a similar road. Thanks!
  5. deto
    deto
    Here you go. Not my best work, but it will do the trick...
  6. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
  7. deto
    deto
    It's been awhile. Been busy with work. Got the shifter mounted and adjusted. Ordered a rebuild kit for it too...
    kiwijeff, slammed and daddio211 like this.
  8. Nicely done. I scrapped the headers on my build, going with rams horns manifolds, makes the clutch-slave mount and plumb a lot easier.
  9. deto
    deto
    I'm ordering u bends today so u can clock the collectors down and away
  10. That would help. It also doesn't look like you'll have much adjustment at the fork either, but maybe you won't need much.
  11. deto
    deto
    I'm assuming lots of adjustment is for a mechanical set up rather than hydraulic. Hopefully I'm assuming correctly.
  12. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    All I can say is that I'm glad you are way further with yours than I am with mine. I'm learning a ton from your thread. I'll probably be hitting you up for one of those motor mount setups you made whenever I get there. I really like the way you did that. It just looks right.
  13. deto
    deto
    Thanks man! I'm glad it's helping somebody out.
  14. Here's my slave set up. I used the Speedway rod, just not on in this picture.
  15. deto
    deto
    That's definitely a plus to the cast iron bell. I have delusions of grandeur of actually racing this thing on stage II of the build, so I went with the scatter shield
  16. deto
    deto
    Got my body mounts and bolt kit today. Also got a 3" u bend to clock the collectors away from the clutch slave and frame. Bought the t handle hex key set cuz I needed to spend $0.96 more to get free handling. More tools!
  17. The bell is actually a 1955 Chevy piece, thought it was from a newer Chevy truck. Takes the bigger clutch and the starter bolts to it. Lots of advantages to using the truck stuff.
  18. deto
    deto
    Pushed the body outside to hose it down blow out all the dust before it goes back on the frame for rust repair and squaring up.
    daddio211, cretin and slammed like this.
  19. deto
    deto
    Pulled the motor, pulled the wheels, dropped the frame on the ground with some wood underneath, and had 8 rugby players lift it on. Success.
    kiwijeff, daddio211, 62hotcat and 2 others like this.
  20. deto
    deto
    Got the nice motor on the stand and the mock up bolted together to go back in the chassis. Don't want to get the pretty one dirty with all the cutting and grinding.
  21. Did the mock up thing with my Ford as well... had to, good engine is in the shop.
  22. deto
    deto
    Trimmed the firewall braces. I left the outside frame mounts, because I like these braces, and everybody just ditches them when they do the v8 swap. I'm going to fab some that go around the motor and clear the steering while keeping the same frame mount location.
  23. deto
    deto
    More progress. Got the body squared up on the mounts, started bagging and tagging interior goodies, pulled the seats, and started to assess the rust situation.
    daddio211 likes this.
  24. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Now for the fun part. Your car looks to be in pretty decent shape though. Keep it up!
  25. 56sedandelivery
    56sedandelivery
    deto, How about a part number/make/year-car your headers were designed for? Start making those Motor mount/trans crossmember parts to help finance the 49 Coupe! Our 51 Bus Coupe is currently parked outside. We've been getting LOTS of rain and wind. Water apparently seeped in through the hood molding/split, and saturated the open element air cleaner, then went down through the carb, into number six intake port, and locked the engine up when I went to start it. I pulled the plugs, and spun the engine over, blew the water out (was't much thankfully), reinstalled the plugs, and it fired right up. NO water in the oil, no signs of a bent rod or anything. The engine is now covered with a plastic garbage sack to keep the water off. I am Butch/56sedandelivery.
  26. deto
    deto
    Butch! good to hear from you.
    Hooker Headers 2466
    Competition Shorty Headers
    • 265-400 Chevy Small Block V8
    • 1967-81 Camaro/Firebird
    • 1964-87 Chevelle/El Camino
    • 1970-87 Monte Carlo
    • 1968-79 Nova
    • 1.625'' Primary Tubes
    • 3'' 3-Bolt Collector
    • Black Painted
    Chevy/GM Car Chevy Small Block
    Item# 520-2466
    I'm buying all of my patch panels this week and I'm gonna tackle all the repair over Christmas break. If work wasn't so busy I would work on selling kits!
  27. deto
    deto
    Ordered my sheet metal replacement panels today. Should be ripping into it right after Christmas!
    cretin and drdave like this.
  28. deto
    deto
    Had to work during the break. But I'm planning on making the initial cuts over the weekend. Got it cribbed up for my back's sake 1451609561530.jpg
  29. Devin
    Devin
    from Napa, CA
    Sweet! This may be a super dumb question, but how are you going to get the car down from those blocks?
  30. deto
    deto
    Those blocks are all nailed together
    I just used the floor jack I had and it lifted it up enough to slide them under the wheels. Should come down just as easy
