Technical Road Draft Tube Extension?
Discussion in 'The Hokey Ass Message Board' started by blowby, Jun 26, 2020.
  1. blowby
    blowby
    from Nicasio Ca
    A friend has a sweet 57 Bel Air we rebuilt about 30 years ago. Bone stock 283 with a Muncie. He hasn't put a ton of miles on it but is starting to smell fumes in the cab, even after sealing all the floors, shift boot etc..
    He's thinking of going PCV but doesn't want to drill valve covers. He asked about extending the road draft tube. I did this years ago on a tired motor, must have been about 16 at the time, don't remember if it worked. Don't want to dig into the engine runs great, no smoke, just this minor annoyance.
    Thoughts?
  2. tubman
    tubman
    "Red Green" it. Find a suitable piece of tubing and duct tape it on temporarily and see what happens. You can even try different lengths this way too.
    blowby and warhorseracing like this.
  3. I've read that the reason the tube ends where it does is because the air flowing by it creates a vacuum of sorts to help pull the fumes out. But I would find a fitting from a 66/67 that had a pcv inline. Also make sure that the filler tube cap/breather isn't plugged (you can wash it out).
  4. You can convert to a pcv system, there are numerous threads on this site that talk about that. I've used a BBC valve cover grommet in the road draft hole to hold a pcv valve then run a hose to an appropriate port on carb. On a bone stock 283 you will probably need to install a carb spacer with a pcv port.
    vtx1800, blowby and olscrounger like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    You can extend the draft tube with a radiator hose. Used to do it all the time on some of the old trucks I've driven. It would get the end closer to the ground, so hopefully the fumes would go under rather than through the firewall or vent windows.
  6. tubman
    tubman
    I guess "Red Green" isn't big in California (or Alabama either).:rolleyes:
  7. Big in my living room.
  8. I extended the road tube on my Stude pickup farther back under the truck bed frame because I got tired of smelling the fumes.
    Ace Hardware tubing and zip ties solved the exhaust fume smell by moving the fumes to the rear.
    about 25 yrs ago. still doing its job
    WHY BE ORDINARY ?
    blowby, chryslerfan55 and Driver50x like this.
  9. clunker
    clunker
    from Boston MA
    1. MASSACHUSETTS HAMB
    Heater hose worked for me. Also running 1/2 quart low (oil not blood). Thought of converting to pvc, but don’t really like doing things the right way on my own time.
    blowby and TWKundrat like this.
  10. blowby
    blowby
    from Nicasio Ca
    Hey I'm a Red Green fan, just never saw him extend a road draft tube. :)
    Thanks for the replies, let you know how it works.
    scotty t and chryslerfan55 like this.
  11. This might just be the most profoundly, personal insight I've ever seen on the HAMB. :cool:
    I just wish I knew exactly what the hell it meant. o_O
  12. Mr48chev
    All the extended road draft tubes in the world aren't going to help at low speed or at an idle when no air passes the end of the tube to draw air though the crankcase and out the end of the tube.
    The piece that 1oldtimer showed in post 3 is the correct way to install a PCV on that engine and the only noticeable thing without hunting is the hose that runs from it to the intake or carb base.
    That is also standard equipment on mid 60's Small Block Chev V8 engines.
    Seems that we bought them from Chevrolet for under 5 bucks back in the 70's when we didn't jack one off an engine at the wrecking yard. They may be spendy now. https://www.classicparts.com/1956-67-PCV-Draft-Tube-Assembly-S_B/productinfo/86-141/
    The grommet with pcv valve in the hole the draft tube came out of. works fine as long as you leave the baffle in the lifter valley.
    partssaloon, blowby and chryslerfan55 like this.
  13. BamaMav
    BamaMav
    from Berry, AL
    I have no idea of what or who you're talking about. If it's a TV program, I haven't seen much TV in 35 years since I started driving a truck.....
    Elcohaulic likes this.
  14. Almostdone
    Almostdone
    Here’s a PCV installed using the fitting posted earlier. So far I’m using the filter in the cap of the oil filler tube as the fresh air source.
    brEad and blowby like this.
  15. tubman
    tubman
    I know what you're saying, as I winter in Florida and nobody down south knows about him. It's PBS TV show about a bunch of Canadians who live out in the woods and have, umm, I would say, the simple life. One of his "shticks" is that he can fix anything with duct tape. (They also have belt sander races.)
    It is hilarious (since I am from Minnesota and see folks like this once in a while), but it just doesn't work south of the Mason-Dixon line.
    vtx1800 and 67L36Driver like this.
  16. e1956v
    e1956v
    Alliance Vendor
    “Duct tape the handyman’s secret weapon “
    “Don’t forget I’m pullin for ya”
    Rothchilds sewer and septic sucking service
    www.speedoservice.com
    Should I rush your rush job or the rush job I was rushing when you rushed in?
  17. 61Cruiser
    61Cruiser
    I’m with “1oldtimer” on this. Did the same thing on my 61 Belair. No more little drips on the driveway. Except from the c/I p/glide of course.
  18. Mimilan
    Mimilan
    Paul, You can buy a grommet kit that replaces the road draft tube.
    that's what we have in our 57
    https://www.corvettecentral.com/c1-...v-valve-conversion-replaces-road-draft-301229
    You still keep the original tomato can and no mods are needed on the valve covers
  19. clunker
    clunker
    from Boston MA
    Ha!
    I’ve spent a good portion of my life building custom things for wealthy people, everything has to be perfect, I have to agonize over every stupid detail. When I’m on my own time, (doing things for myself), it actually brings me great joy to do things half-ass, take short cuts and make an utter mess. OF COURSE taking the time to properly convert a draft tube to a functioning pvc system is the right way to go. Fuck that. It was way more fun and satisfying grabbing some shitty hose and a clamp and half-doing it that way.
    Now if @blowby didn’t share my desire to make a big mess (even just a little bit-way down deep in his psyche) he would never even consider a hose on a downdraft tube. But he did. I think, as an animal in the wild might signal it’s intent to others of it’s species with a call or a growl, I’m picking up an indication here of similar motivation. Call me crazy...
    brEad and ClayMart like this.
  20. denis4x4
    denis4x4
    from Colorado
    Here’s a Model A aftermarket accessory with a flex tube extension.
    brEad and CME1 like this.
  21. 67L36Driver
    67L36Driver
    Ever since we pulled the valve covers off my buddy’s vet to do the valve lash (30-30 cam) Nov. ‘65, I’ve been a great believer in positive crankcase ventilation. Chocolate shake under the valve covers.
    Added a PCV and no more moisture. Less oil leakage to boot.
    Ford’s beloved flat motors would benefit greatly from a PCV. Or, any engine pre 1963.
  22. blowby
    blowby
    from Nicasio Ca
    This is for a friend Clunk, not me. I'm 3/4 ass or better, I'd probably just drive around with my paint respirator on. He's barely 1/8 ass on a good day so I felt it best to get more suited opinions. He did ask about a tube extension messing with the breathing characteristics, with I thought was a valid concern. An extension should end pointed downward to retain the suction effect me thinks. The pcv conversion are tidy too, his call. I guess the only hard part if finding manifold vacuum. He does have power brakes as I recall.
    Here's an old photo of me working on his engine, coincidentally showing the road draft tube in place.
    clunker likes this.
  23. Truck64
    Truck64
    from Ioway
    It kind of begs the question, if the reason the engine is so stanky is because of excessive cylinder blowby, a PCV system isn't going to work very well at all will it?
    Johnny Gee likes this.
  24. I'd thought of a few different interpretations of your philosophy quoted above, and some of them weren't encouraging. :confused: Thanks for clarifying the logic to your approach.
    The expression "Don't let perfection get in the way of progress" seems to sum up your mindset here. ;)
    clunker likes this.
  25. HEY! We get PBS. We have to go up the hill and turn the antenna but we do get PBS.
    ClayMart and blowby like this.
  26. jimmy six
    jimmy six
    Blowby, I don’t have PCV system on my engine either. To take away the smell I bought a Stant oil fill “breather” cap with a 1/2” hose fitting and ran a hose in to the air cleaner to an 90* fitting I found in front of the carb. Takes the smell away. I’m sure if you had a lot of blow by it would be detrimental to your carb and you would at least be looking at new rings. Mine just helps with smell and when I pull into the garage.
    Not sure but I’m guessing while your driving the 45* angle of the road draft tube is pulling the blowby out of your engine and at idle your sucking out with the carb(maybe). Anyway it sure helped with my smell. Every thing was under $10.
  27. Yes, it will cut down on the smell at idle......but a worn engine is still a worn engine.
    BTW, if the correct fitting can't be found used (new ones are pricey) you can modify the road draft tube to fit.
  28. blowby
    blowby
    from Nicasio Ca
    OK to Tee off the power brake port for the PCV kit?
  29. Mimilan
    Mimilan
    Where is this port? In the carb or the manifold?
    With the power brakes it only draws a vacuum NOT flow [so maximum volume is when the diaphragm is fully displaced]
    The PCV it pulls volume of air [it breathes]
    Having the PCV draw air into the manifold can lean out those particular cylinders.
    The PCV port on a carb is best
