where can i buy the stock rivets that hold the locking brackets to the hood sides on a 36 chevy pickup jim carter does not list them neither does chevy of the 40's thanks
Budda Boom Budda Bing!!! Earplugs......They are probably steel rivets and as @Mr48chev said tools such as Rivet Gun, Rivet Set, and appropriate Bar with correct rivets. Aircraft Spruce, Hanson Rivet are a couple of other places you may be able to order what you need.
I have installed a lot of rivets using a ball peen hammer and a piece of angle iron taped to a heel dolly . This makes it easier to hold onto. I drill the rivet head size into the angle iron so the head doesn’t mushroom. I am able to install steel rivets this way, I agree McMaster Carr will have everything you need. Hobo Jim
