What cfm are 1.5" riley carbs? Is it possible to run two of these on a 100 cubic inch MG? I am guessing too big of total venturi for this size of motor? When you hit the throttle cam on a riley the float level changes? Is this how the enrichment works? Any links to how these gems work is appreciated. Thanks alot!
I don't my friend does, I found that book way overpriced OR I'm cheap one or the other. I will look into it.
FINE! That make perfect sence now. Send me a PM with your address and I'll mail you copies of an original George Riley Carb setup instruction sheet from 1947. This is a four page deal and should answer your questions.
