Right angled brake fittings ????
Discussion in 'The Hokey Ass Message Board' started by Stovebolt, Mar 17, 2009.
  1. Stovebolt
    Stovebolt
  2. Try Stainless Bitz in Caloundra. I think that's how they spell it. They have ads in the local mags. I assume you're after a banjo with a thread poking out at a right angle?
  3. Phil1934
    Phil1934
  4. Older Ford trucks had a banjo and an opening for a steel line. Not sure if was 3/16's are 1/4.
  5. striper
    striper
    I have a feeling Highway Clutch and Brake in Campbellfield might have them. Ring first. I wanted to use them out of my M/C which is a HQ. Trouble is the M/C has an inverted flare to seal whereas the banjo fittings rely on a washer and the banjo bolt would have bottomed out before the washer sealed. How are you using them?
  6. ECIGUY
    ECIGUY
    Pure Choice 520-505-8355 has banjo fittings.
  7. i have used the banjo fittings from Pure Choice Motorsports , they can really help if your MC is in a tight spot
  8. Stovebolt
    Stovebolt
    Thanks guys.
    I'm using a Ford Master cylinder, and the fittings are on the left side of the MC.
    Running a right hand drive car means there is little room between it and the clutch pedal assembly, and clutch MC.
  9. panhead_pete
    panhead_pete
    Call Alex 5491 7688
    Ive known him for over 25 years and he is a stand up guy.
  10. spookydave
    spookydave
    I don't want to spam but you did ask.
    I make hose fittings and DOT brake hoses. I have piles of different fittings. Figure out what size banjo bolt you have and give me a call @ 714 223 9322. just noticed your location, maybe email is easier. [email protected]
    I should have what you are looking for in both -3AN and 3/8-24 inverted flare.
    I was just thinking about becoming an Alliance vendor. Maybe now's the time to get that going.
