Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Rich B.
    Rich B.
    from Portage,IN
    Heres a pic of the dummy rear end. It has slip tubes to set rear end width.
    Here I'm trying to finalize ride height, tire clearance, and body rake.
  2. That dummy rear end is a slick idea! Love the stance in that last pic.
  3. -Brent-
    -Brent-
    I'm going to plate/reinforce my hanging pedals, too. As well, I'm going to tie that area in to the dash bar to reinforce and remove any flex.
  4. Rich B.
    Rich B.
    from Portage,IN
    Brent:
    I’m very happy with mine, there is no flex , feels
    rock solid when braking. I wish I would have raised
    the master cylinder a few inches higher. It would
    Make the pedals a little more comfortable. Mine is
    fine, but be aware of the possible problem . We step
    on the pedals with our toes basically at a 6-1 ratio.
    Leave enough room so you’re heel doesn’t hit the floor.
    Rich
    kidcampbell71 and loudbang like this.
  5. Rich B.
    Rich B.
    from Portage,IN
    brEad, 32SEDAN, mgtstumpy and 4 others like this.
  6. Rich B.
    Rich B.
    from Portage,IN
    Finished installation. I had to box the rear 32 rails, add a cross memeber, and
    a lot of fussing around to make the tank fit.
    It would seem that tieing into the sides of the frame would be more logical, but
  7. Rich B.
    Rich B.
    from Portage,IN
    I made all the brackets for the panhard bar so that it would be level with frame.
    There is also ajustment at frame tie in.
    Vic Walter, nunattax, brEad and 6 others like this.
  8. Rich B.
    Rich B.
    from Portage,IN
    I used 1 1/2' square tube with 3/16" wall for all frame mods. A207.JPG A208.JPG A209.JPG
    The trans mount has 3/8" nuts weded inside frame for attaching mount.
    I made the coil over mounts with the option to change angle if needed.
  9. Rich B.
    Rich B.
    from Portage,IN
    I hated replacing original crossmember, but engine set back gave me no choice.
    It had been in there over 80 years, at least I kept the rear crossmember. I made
    a fancy new K member (sounds good) that also ties into wish bone brackets.
    they were located on the inside of frame to give me full turning radius with out the tire
    hitting.
    Vic Walter, brEad, 32SEDAN and 6 others like this.
  10. Rich B.
    Rich B.
    from Portage,IN
    Have most everything tacked together here.
  11. Rich B.
    Rich B.
    from Portage,IN
    Finally got all rearend peices tacked on This is a late 70's rear end with 3 1/4"
    diameter, and 1/4" wall housing. Had to modify all parts to fit because of larger size.
    I also added some reforcing plate at coil over mounts. I picked up the rear end from the junkyard,
    cut all the old brackets off . It’s a 31 spline w/posi, and 3:50 gear.
  12. Rich B.
    Rich B.
    from Portage,IN
    Back from Mosers with completed rear in. arrived 8:00 am, and left at 11:00
    for 3 hour ride home. They will not guarantee housing warpage unless they weld it.
    they laser check all cut points, and mounting brackets are correct. I was spot on so they
    knocked a $100 dollars off price. I left the center section with them for rebuild, and
    gear change, 3.50 . 3 days later I received rebuilt center section from Moser.
    brEad, 32SEDAN, mgtstumpy and 7 others like this.
  13. What a treat Rich. Nice review for those of us that have had the privilege and pleasure to see you work your magic over the past decade. Time do fly...……….. The folks who are new to this project have some more treats ahead as you wind to the finish.
    Rich B., kidcampbell71, Thor1 and 2 others like this.
  14. Rich B.
    Rich B.
    from Portage,IN
    Vic Walter, brEad, mgtstumpy and 6 others like this.
  15. Rich B.
    Rich B.
    from Portage,IN
    The long slot is for panhard bar clearance (if needed), I know a lot of people trim
    this part of the cross member for cleaner looks, but I feel it adds a lot of
    stength to the chassis. I also notched the frame for front spring clearance.
    Vic Walter, brEad, mgtstumpy and 5 others like this.
  16. Rich B.
    Rich B.
    from Portage,IN
    rearend cleaned primed, ready to make it a roller finally
    Vic Walter, brEad, mgtstumpy and 7 others like this.
  17. Rich B.
    Rich B.
    from Portage,IN
    I didn't like the clamp supplied with the steering stabelizer so I made my own.
  18. Rich B.
    Rich B.
    from Portage,IN
    I'ii go back later, and show the bolt on shock mounts.
    Also I changed the steering stablizer mount.
  19. Rich B.
    Rich B.
    from Portage,IN
    All together with webbing taped to frame top, ready for body.
  20. mkebaird
    mkebaird
    Beautiful work. This will be a sweet car. My avatar was a ten year project, so I know something of the dedication it takes to finish.
  21. Rich B.
    Rich B.
    from Portage,IN
    Mkebaird: Thanks for the kind words! I sure have a soft spot for the early
    Vettes! You sure have enough cars to work on!
    I had a few interruptions while working on my
    Coupe which slowed some of the progress. This
    Build log will reflect that as I post , some were
    By choice, some health problems.
  22. Rich B.
    Rich B.
    from Portage,IN
    A friend of mine needed some work done on his 28 Dodge 4 door sedan.
    I moved the *roller* to the other side of the shop. (it may be 2 car garage,
    but I work on cars not park them so it's a shop) At least that sounds good to me !
    This may not look like a 4 door sedan, trust me that's what it was. dodge1.JPG
  23. Rich B.
    Rich B.
    from Portage,IN
    Another friend had started the transformation! The windshield is a swap meet
    piece of unknown orgin. A 3" tube had been used to cap doors and body. also
  24. Rich B.
    Rich B.
    from Portage,IN
    I started welding up 36 holes in the firewall. Part of the new toe board
    is visible on pass side.
    The new trans tunnel was simple, but I also added a lot 1/4" plate behind
    the side kick panels so their was something to tie swing pedals in. dodge5.JPG dodge4.JPG dodge3.JPG
  25. Rich B.
    Rich B.
    from Portage,IN
    The front seat needed a little repair. the back of the seat is a tie in point
    Vic Walter, brEad, mgtstumpy and 4 others like this.
  26. Rich B.
    Rich B.
    from Portage,IN
    I rebuilt the top half pass side, repaired *B* pillars , and finished seat. That's
    2 pices of plywood with the bottom piece cut back to lock into the seat. dodge10.JPG dodge9.JPG dodge8.JPG
  27. Rich B.
    Rich B.
    from Portage,IN
    The rest is rust repair, but we all love pics! This panel was already started , and started rusting.
    I cleaned it up and fabbed a new door bottom.
    Now you must realize there is two guy's helping out here. DSC01821.JPG DSC01822.JPG DSC01825.JPG DSC01824.JPG
  28. Rich B.
    Rich B.
    from Portage,IN
    DSC01830.JPG DSC01833.JPG DSC01835.JPG DSC01836.JPG Rust, rust, rust......
  29. Rich B.
    Rich B.
    from Portage,IN
    Vic Walter, Rathbone, brEad and 4 others like this.
  30. Rich B.
    Rich B.
    from Portage,IN
    I have had good luck using step dies in my bead roller to help make a smooth curved
    Vic Walter, brEad, mgtstumpy and 2 others like this.
