Technical Residual brake valves. Any one have a preference?
Discussion in 'Traditional Hot Rods' started by drmrman, Nov 30, 2013.
  1. drmrman
    drmrman
    from new Jersey
    I set up my brake system with (2) 10psi residual valve 1 front 1 rear! Worked great for a short while.... Put about 150 or so miles on it and now I have to pump the pedal to get the brakes up. I've narrowed it down to the front. Going to assume the residual valve took a poo.... I'm using speedway brand valves. Anyone have any preference on a more reliable brand? These little guys are 35$ each and I don't want to have to replace them every 150 miles.
    Thanks! All input is appreciated!
  2. drmrman
    drmrman
    from new Jersey
    Also if you need more info it's a '40 set up... New master from earlfordparts.com and completely rebuilt drums.
  3. unkledaddy
    unkledaddy
  4. drmrman
    drmrman
    from new Jersey
  5. Jason455
    Jason455
    Wildwoods are good. 10psi for drums 2psi for disc
  6. Autodave
    Autodave
    from Menifee,Ca
  7. DICK SPADARO
    DICK SPADARO
    It might not be the Residual Valve is the problem. First re adjust the brakes and Re bleed. This will help eliminate any other potential issues before you look at the line valve. If you still dont have brakes up front the next question was this working correctly before you installed the line valves or is this a new installation? If its a new installation , do you have the correct master cylinder to correspond with the unit. If it was an old installation up graded you could have contamination in the check valve preventing it from operating correctly. These units can be cleanned with brake clean.
    My opinion the better units are the brass ones made by ECI in CT. The aluminum units are for race car application and really not intended for street use because of corrosion issues.
  8. Mr48chev
    Having to pump the brakes to get the pedal up means that there is air in the system.
    From personal past experience I am thinking you have a leak in the system that is letting air be drawn into the system. Check all of the connections and fittings in the lines to the front brakes. Especially check any that you flared yourself as even the very tiny imperfection may allow it to suck air in but not show a fluid leak that is visible. I had that happen on the wife's ot mini van when I replaced the antilock brakes with regular booster and Mc and had to swap some brake lines to get things to work.
  9. jw johnston
    jw johnston
    Why are you even running a residual valve with early ford juice brakes? They don't need one.
  10. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I used the Wilwood's but I can see how they get a bad rep with them being aluminum and over tightening can lead to them splitting. I hear great things about the brass ECI ones posted above ^^^^.
  11. drmrman
    drmrman
    from new Jersey
    Yes the brakes were working perfectly before. the only thing that isolates the front and the rear is the residual valves. The master cyl only has one port out and it tee's front to rear.
    No old units. Everything is new. and I built the lines front to back.
  12. drmrman
    drmrman
    from new Jersey
    Not necessarily. The springs on the shoes over comes the pressure in the line and pulls the shoes away from the drum. Then you have to pump the pedal to get the shoes back against the drum. When I first installed the valves when you would spin the wheel off the ground you could here the shoes dragging ever so slightly now... they pull so far away the wheel will spin forever with no drag, this is why I think it is a failed valve.
    I will tighten all fittings again but there are no fluid leaks, and the soft pedal comes back within 15-30 seconds. Just enough time for the spring to pull the wheel cyl back together.
  13. drmrman
    drmrman
    from new Jersey
    I will have to check them out! Thanks
  14. Couple of things.
    Stock single master should have a residual valve built in, should not need to add external valves.
    Residual valves will not overcome the
    the force of the return springs. Not what they are intended to do.
    Re-adjust the brakes so you have a slight drag again.
    If they are '39-'41, check for in-correct initial adjustment of the lower cams.
  15. gimpyshotrods
    gimpyshotrods
    Reset the shoe drag.
  16. DICK SPADARO
    DICK SPADARO
    The upper hex head cam stop at the 10-2 position of the backing plate is the adjuster for the brake return. These cams prevent the shoes form returning too far and requiring double pumping the master cylinder to get braking. If these cams are broken off or not there the brakes will retract too far and you double pump. If you have 39-41 backing plates the lower anchors must be adjusted before the top stops. The top stops are then rotated out until the shoe just drags on the drum or some times locks the drum and backed off one flat. If you do not know how to adjust old Ford brakes or need a refresher do a search on HAMB or web. The 42-48 only require the upper cam stop adjustment but require the shoes to match the arch of the drums.
    If you have a stock master cylinder you do not need the residual line valves as the master cylinder already has one installed.
    I have a feeling that the drums you have are oversize by too much and as the brake shoe wears the high spot it looses the correct adjustment. Quick question, do you get brakes back after pumping pedal twice or do they remain soft?
  17. drmrman
    drmrman
    from new Jersey
    On my iPhone. Sorry this message is short.
    Yes after I pump 2wice the pedal comes back.
    I will re adjust the drag on the brakes. Possible everything loosened up.
  18. drmrman
    drmrman
    from new Jersey
    It was the valves. Purchased a pair from ECI last month and just got around to installing them this afternoon. Truck has sat for about 2 hours and the pedal is still solid.
    Thanks for the help guys.
    Joe
  19. Fenders
    Fenders
    Maybe I missed it but why do you need two resid valves?
  20. gimpyshotrods
    gimpyshotrods
    One for the front brake circuit, and one for the rear brake circuit.
  21. Mart
    Mart
    Well, I'm glad it appears to be working, but there are 2 issues here. 1, if it is an early Ford master cylinder, it should have a valve built in. 2, If it isn't an early Ford cylinder, and does not have a valve, as it is a single port cylinder, just one on the exit of the cylinder would have done the job. You could tee front and rear after the valve. You seem to be adding unnecessary complexity. I just use all early ford stuff and put them together like Henry did.
    Nice looking truck by the way.
    Mart.
  22. hotrodderhaag
    hotrodderhaag
    Mart,
    I have the same setup as this 32 pick up from the original post... And I too had to run residual valves. My system was all the same, all new master , all new brakes. Adjusted brakes properly . No air leaks, no fluid leaks. Even with the shoes adjusted out to the drum, I had a soft pedal. It was fluid coming back to the master. If you pumped it 2 times, it was hard as a rock as stayed that way under pressure.
    Installed 2 residual valves, fixed it right up.
    I didnt have this problem on my model a when I switched it over to 40 brakes, but when I lowered the car and the wheel cylinders where higher than the master cylinder, that's when the troubles began
    Mines assembled how Henry did, pretty sure these new repop master cylinders just plan suck ass
  23. DICK SPADARO
    DICK SPADARO
    There still is a question about master cylinder internal residual pressure ports. Something doesnt make sense if you are using a stock early Ford master cylinder and it requires line valves to make it function. The early Ford cylinder already has a residual line valve. This cylinder mounts below the floor board and in stock application mounts below the wheel cylinders so adding extra valving is in question, if you dont need it stock, why do you need it now? My question is what are you using for a master cylinder? This may have more to do with your pedal stroke ratio or pushrod adjustment than the master cylinder. What is or who made the brake pedal assembly?
  24. pasadenahotrod
    pasadenahotrod
    from Texas
    In my experience the Chi-com "hotrod" "corvette-style master cylinders are garbage. USA made cylinders 39-48 Ford or even Corvette should still be available… buy them.
