Hot Rods Replacing shocks on my 46 ford
Discussion in 'The Hokey Ass Message Board' started by hotrodyankee, Dec 17, 2016.
  1. hotrodyankee
    hotrodyankee
    Looking to replace the lever shocks on my 46 ford, any suggestions on what to use for the front and rear? The rear is gonna have a reversed eye spring and the front is gonna have a 4" dropped axle. Thanks for your input.
  2. Tim
    Tim
    from Raytown Mo
    As far as an off the shelf shock or for mounts?
  3. WiredSpider
    WiredSpider
    Chassis engineering
    hotrodyankee likes this.
  4. hotrodyankee
    hotrodyankee
    Tim, looking for the mounting. Thanks.
  5. Tim
    Tim
    from Raytown Mo
    I think the best option if possible to to find late 47 to 48 stock mounts. They came with tube shocks stock.
    The front axle had a stud on it for the lower mount, some people drill and bolt one on other weld a stud on. The rear Bolted to the backing plates.
    I'll take some photos for you when I get a chance of stock mounts if no one beats me to it
    LOU WELLS and hotrodyankee like this.
  6. Jalopy Joker
    Jalopy Joker
    also, take a look at speedwaymotors.com - on front I used shocks that were designed for rear of mid- 60's Corvette
  7. hotrodyankee
    hotrodyankee
    Thanks for your help!
  8. Tim
    Tim
    from Raytown Mo
    No problem, was three feet away from them all afternoon but still forgot to get a photo. I'll make sure you get one my tomorrow night. They are just on a shelf
  9. Tim
    Tim
    from Raytown Mo
    Alright I remembered :) these are the rears. I'm holding the part that would bolt to a backing plate IMG_4834.JPG IMG_4835.JPG And some krusty fronts that I think bolt onto the stock holes that the lever shocks do IMG_4836.JPG IMG_4837.JPG IMG_4838.JPG snout faces forward.
    So that's a front upper and a rear lower mount :)
  10. hotrodyankee
    hotrodyankee
    Thanks
    Thanks Tim, you are a great help! Did more digging , and those are the mounts that I came up with also. found a set of NOS fronts, and the rears you can buy from a shop right here on the Hamb. Just have to find the correct shocks now. Thanks again.
  11. Tim
    Tim
    from Raytown Mo
    I'd bolt up all your mounts and measure, I know with mine lowered it was some try and see tuning to find one that fit
  12. I have a spare set of front shock mounts if you need them
  13. hotrodyankee
    hotrodyankee
    Thanks Chris, I located a pair of NOS ones, will let you know if deal falls through.
