So , if I replace my model A front axle with a '36 front axle...and not change anything else..How much will it lower the car?
And I do believe that keeping some kind of '28-36 spindle and kingpins should be part of your option package. The common '37-48 types will jackitrightbackup significantly. Also if you are using mechanical brakes you will need some messy modifications to connect point A to point B.
