Technical Repairing Ford Banjo Rear Hub
Discussion in 'Traditional Hot Rods' started by 66Coronet440, Jan 9, 2023.
  1. 66Coronet440
    66Coronet440
    I was reinstalling a '42 Ford banjo rear hub yesterday, and a piece of the outer lip broke off (from drum). I'm not sure why...maybe it had been dropped previously. Would it be safe to repair, or should I look for a replacement?
  2. Pics would help.
  3. Kiwi 4d
    Kiwi 4d
    I think folk try to hammer the drum off the hub and so break a chunk from the outer lip. Rather than use the correct puller. Generally good enough to run as is but picture would be helpful.
    Outback and 34 GAZ like this.
  4. Do you mean the edge of the drum where people force a big screwdriver between drum and backingplate in a effort to pry drum loose ? A small crowbar can damage the drum as well.
  5. Kiwi is faster :D
    Outback likes this.
  6. 66Coronet440
    66Coronet440
    Here's a pic. I extracted it with a puller, but there's certainly a chance someone tried to pry it.
  7. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    U could just remove that lip,all the way around,or put the part back with brazing
  8. wheeltramp brian
    wheeltramp brian
    Grind it smooth and don't worry about it
  9. BJR
    BJR
    If you don't re-attach the broken off piece, the drum will be way out of balance.
  10. Run it.
    NoSurf likes this.
  11. 66Coronet440
    66Coronet440
    I had planned to re-attach it. While it would be out of balance, that section is paper thin compared to the rest.
  12. sdroadster
    sdroadster
    J.B Weld it back in place.
  13. Andy
    Andy
    Cast iron rod. Bevel a little and just weld the ends. Let it cool between welds
  14. Kiwi 4d
    Kiwi 4d
    I doubt out of balance is a major concern as it is so close to the rotating centre, and the possibly of imbalance is of negligible influence . Its been done for decades with chipped drums. Its not structural , so anyway you attach the separated piece would work if even you feel the need to repair it.
    Atwater Mike and 66Coronet440 like this.
  15. footbrake
    footbrake
    Forgetaboutit!
    Kiwi 4d likes this.
  16. SASROD
    SASROD
    Just cut that much off the opposite side.:)
    Kiwi 4d and seb fontana like this.
  17. Atwater Mike
    Atwater Mike
    as it is so close to the rotating center, and the possibly of imbalance is of negligible influence .
    THIS.^^^^^ It would take a machine calibrated in micrograms to ascertain unbalance so close to center. Sheesh!
    Kiwi 4d likes this.
