I need to get three roll pins out to replace gears on a planetary. They are 5/32 OD. ID is just a hair too small for #6 tap. But too hard to get it to bite. No clearnace at bottom for pick. I started drilling, but slow. Is there a trick or do I just cuss whoever put roll pins in blind holes?
Got it. BFH. Just drove out the shafts. Holes are no longer blind so I can drive out roll pin pieces.
We have hydraulic 8000 ft lb drill heads mounted on Bobcat skid steer loaders to scre piling in the ground for residential construction.
i was gonna say that you could maybe try the old "grease in the hole" trick. it works mainly for bringing out bushings in blind holes but it might work on roll pins too. how it works is , fill up the hole in the center of the bushing / pin, and find a pin punch/bolt/wood dowel that is pretty close to the the inside diameter of the same hole. then hit the driver with a hammer. the grease doesnt compress but will get under the pin/bushing and slowly push it out of the hole. but the way you did it is effective too, just a little more painful.
