Technical removing old pitted chrome plating
Discussion in 'The Hokey Ass Message Board' started by upspirate, Oct 9, 2017.
  1. upspirate
    upspirate
    How do you remove old chrome plating?
    I've got an old shifter handle that is badly pitted, and just want to remove the pits and smooth it out for paint....not going to have it re-chromed, just want it smooth.
    I've tried wire wheeling it, but that didn't work well. Any ideas for me?
  2. upspirate
    upspirate
    I know it's an O/T part, but the process should be the same as say a Hurst shifter handle
  3. squirrel
    I had a chrome shop do that on a few parts, years ago.
    junk yard kid and upspirate like this.
  4. upspirate
    upspirate
    Jim,If I was going to re-chrome it I would do that, but don't want to spend that much money or time on this project
  5. 56premiere
    56premiere
    I've heard muriatic acid. Not sure
    upspirate likes this.
  6. rjones35
    rjones35
    Grinder, then smooth it out again.
    Bugguts and upspirate like this.
  7. upspirate
    upspirate
    Yea, thought about maybe a grinder or a flap wheel.....
    rjones35 likes this.
  8. squirrel
    Since it's a relatively small part, grinding will work. Have fun, be careful.
  9. upspirate
    upspirate
    Yep, tired of getting crap in my eyes.....eye protection now days
  10. mohead1
    mohead1
    Flapping wheel or a flapping disc on a grinder....that way less chance of excessive material removal
    Sent from my SM-G900V using Tapatalk
  11. upspirate
    upspirate
    Thanks , have to try that
  12. redo32
    redo32
    Hey U P... What is the shifter off of? I don't recall ever seeing one like that. It appears to be die cast potmetal. Do Not soak it in muratic acid..IT WILL DISSOLVE. It can be reverse stripped in sulfuric acid, but if you don't want to farm it out to a plating shop, the best bet is to sand it down with flap wheels.
    Lowdownfab and upspirate like this.
  13. Chiss
    Chiss
    from S.C.
    A Drimmel will give better results, especially in the groves, more control and less Material loss.......
    46international and upspirate like this.
  14. ceege
    ceege
    from NW MT
    Hit it with a sand blaster. Hit it with epoxy primer. Hit it with a lot of surface primer. Sand smooth. Top coat with your desired finish.
    tb33anda3rd, da34guy and upspirate like this.
  15. What ceege said
  16. alchemy
    alchemy
    I would put in the blasting cabinet. You can go easy on it until you see how the parent metal reacts.
  17. The no-labour no-grinding crud method is to remove it the way it went on- electrically.
    Google and a battery charger are your friend.
  18. Just begin the de-pitting process and the chrome will be the first to go.
    To get the pits out the entire surface comes down to level of the deepest pits. Blasting works to remove the chrome and the crap in the pits and that leaves you with clean pits. Then you need to start the de pitting/grinding process
    mike in tucson and upspirate like this.
  19. simpsonrl
    simpsonrl
    Just out of curiosity, if the part was to be re-chromed, how would you go about repairing / filling the pits? Maybe some of the those magic solders that fix aluminum?
  20. upspirate
    upspirate
    The handles are made of brass with chrome plating.
    The pits don't go beyond the chrome in this case, but that is a good question.
    I'm just going to smooth it best I can and paint, probably with hammer-tone paint for my application.That way the surface won't be noticeable yet it won't be rough and corroded either
    I think the chrome shops do the repairs, but not sure what they do.
    simpsonrl likes this.
  21. redo32
    redo32
    Hey UP , we talked about the handle being brass, but as I go back to the pictures it still looks like potmetal to me. Brass will usually not corrode that way. Never the less, still a good deal to use flap wheel very carefully until you get a feel for the base material. Watched a guy in a plating shop lean on a belt buckle and it literally melted away. It was made of pewter and is very soft.
  22. upspirate
    upspirate
    The pitting is in the plating, not the base metal.I was going by the link I PM'd you that said the parts were brass.
    I would have thought them bronze in that application.
    Anyhow, I will go lightly as I've never used a flap disc before.
    H-D had so many different sizes and arbor sizes that I had to come home and see what my angle grinder is as I haven't used it in a while.
  23. All I know is powder coating has gotten so cheap I would just do that. Pick any color and be done with it.
  24. There was a thread on here recently on "Muggy weld" die cast repairs- interesting stuff.
  25. Los_Control
    Los_Control
    from TX
    while bored watching news, I used sand paper to clean the chrome off my gauge bezels, wanting the brass finish instead .... it was good chrome when started.
  26. Fortunateson
    Fortunateson
    To fill pits have the old chrome removed and then have it "copper struck" (copper plated). Then simply fill the pits with solder. Sand and then polish. Send for chroming.
    simpsonrl and upspirate like this.
  27. More than likely that was nickel plating, if it was just over brass.
    upspirate and Los_Control like this.
  28. simpsonrl
    simpsonrl
    Is that the way to do it even if the base material is zinc die cast or pot metal or similar? Thanks
  29. The Shift Wizard
    The Shift Wizard
    Put a magnet on it. I wouldn't be surprised if the brass you're seeing is also plating.
    It almost looks forged to me.... unless you see some mold lines
