how difficult is it to remove a ifs on an old 70's style 1930 coupe and add the traditional style front suspension such as a beam axle? can you just wack it off frame with a torch and add the beam axle setup? example below..looking at this car but i dont care for ifs at all
not hard at all. its a little time consuming when it comes to measurements for caster and positioning the steering box/ column but i did it to a 1949 chevy business coupe, and im only 19. the 49 had it's factory ifs. we chopped off the spring towers, welded them up and went on our merry way.
You have more involved than taking the MII stuff off. First it looks to me like the original frame is not even under there. As far as I can see it has been sub framed from just behind the firewall.
might look at pickin up a set of rails and buildin a new frame then sell the one you have to some guy thats gotta have IFS
if memory serves me , it has a 64 impala frame and frontend, didnt really mind the frame part, i just dont like the look of ifs on any thing fenderless, i was going to channel it over the frame anyway if i bought it. thanks
stay away from that car if you want an axle under your HOT ROD. for as much of the frame that needs to be replaced you'd be better off building a new one. the 49 above is a whole different deal. the IFS comes off in one big piece and you are left with nice straight frame rails to work with.
It looks like you wouldn't be using the frame; you are buying a pile of parts. Don't pay to much. Neal
didnt see the picture when i posted before, i mean, if you dont care if its got the more modern subframe than go for it. But i say build a new subframe and i guess now its a LITTLE bit more complicated if youre building yourself a new set of frame rails but. but in my opinion, with this particular car. i would want original chassis, not even square tubing it myself. but its your call. we're all here behind you (almost 100%!) no matter what you do(with some exceptions)
