Hot Rods Removing 1 Shot lettering paint question
Discussion in 'The Hokey Ass Message Board' started by chopnchaneled, Sep 20, 2019.
  1. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Any ideals ? Got some 8-9 year old lettering that needs to be gone.
    Thanks
  2. Ez off oven cleaner...test an area. Is the car BC/CC?
    56shoebox likes this.
  3. Bandit Billy
    Bandit Billy
    ^^^X2...and don't get the "eco" friendly option. It isn't HAMB friendly.
  4. 4wd1936
    4wd1936
    from NY
    I had a similar question on here some time ago and many suggested EZ off. They were right and it worked well.
    jim snow likes this.
  5. jim snow
    jim snow
    X3 on the e-z off. Snowman
    lothiandon1940 likes this.
  6. oldiron 440
    oldiron 440
    Scrape off with single edge razor blades, keep using new ones until done.
  7. oldandkrusty
    oldandkrusty
    Ditto for the E-Z Off! It works like a charm.
  8. E-Z OFF !
    Just use rubber gloves it may burn you
  9. oldiron 440
    oldiron 440
    EZ OFF works of a factory finish without hurting the paint but I have seen it bite into many types of sprayed automotive topcotes. So if your car has been repainted be very careful.
    rod1 likes this.
  10. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Thanks !
    Guess i need to find out what type of paint was used to paint the car
    all over, kinda looks like a flatner has been added to make it a primer
    type navy blue.
    Stay tuned, going to try a spot and see.
    kidcampbell71 likes this.
  11. jimmy six
    jimmy six
    Use very short brissels. I cut a real cheap 1/2” brush with it cut to 3/8”-1/2” brissels...
  12. I have used lacquer thinner, I've never used easy-off to remove one-shot but I have used lacquer thinner, the process is slow but it is less likely to damage/dull the cars paint. HRP
  13. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Thanks for the replies, Easyoff oven cleaner worked really good,
    Learn something every day on the HAMB !
    OH" and i did use a box of single edge razor blades :)
  14. low budget
    low budget
    from Central Ky
    I would like to see a video sometime with someone using the easy off and or razor blades.
    I have used razor blades to take the paint off a couple whole cars for the most part but they were also getting sanded and a repaint.....I would be very uneasy and skeptical about using a razor blade on top of good paint I wanted to keep??? they will make a scratch and a gouge here and there.....I have also used the plastic blades you can get at the paint store....maybe they would be better for something like that, or maybe not as they seem to be just as sharp???
