I made myself a tool to remove the bushings from a model-A rearspring. It works so good i want to share it if some other needs one. The inner dia was betwin 9/16 and 5/8 so i take a 5/8 bolt to start with. I grind down the threads until it slides in the bushing. And to make sure it wont go in and widen the bushing i weld around where at the threads end. Then grind down the weld to just smaller dia then the bushings outer dia.
I could have used this about a month ago. I was trying to push out a bushing from a wishbone. This would have helped a bunch. Thanks for posting.
