Technical Remove heat bluing from stainless
Discussion in 'The Hokey Ass Message Board' started by coilover, Jan 30, 2016.
  1. coilover
    coilover
    from Texas
    Need to remove heat bluing from stainless caused by welding to the back side without scratching up the front side. Any suggestions? Thanks.
  2. john worden
    john worden
    from iowa
    Motorcycle shops sell "Blueaway" for that.
  3. vtx1800
    vtx1800
    When I was bending the stainless window trim for the 49 in the Avatar I used heat to bend it and it did blue, I just buffed it out on the wheel with white buffing compound. Good luck.
  4. nunattax
    nunattax
    you could use solvol autosol stainless polish.will also work on chrome and alloy but easy on the chrome its corrosive and will soon wear through chrome.available here at motorcycle shops
  5. This. When I built the grill for my truck I had all the parts pre polished and then just hit the areas that were discoloured by welding it together with a small buffing wheel in a drill and some white polish. It didn't take much effort at all to remove.
  6. Back when I was ridding a old pan head I bought a lot of snake oil products proclaiming to clean up the bluing on the exhaust pipes, nothing worked as advertised. HRP
  7. TagMan
    TagMan
    lothiandon1940 likes this.
  8. I've used Simichrome and also Wenol. Both work reasonably well. Used Blu-Away many years ago, but haven't seen it recently. Not sure if it's still available or not.
  9. Don't know what they call it in the U.S., but I have used stuff called "pickling paste". It's some form of acid.
  10. redo32
    redo32
    A good welding shop might have the the pickling paste.
