Technical Redrill a Ford axle?
Discussion in 'Traditional Hot Rods' started by AGELE55, Jun 4, 2021.
  1. AGELE55
    AGELE55
    Is there enough meat on a Ford 5 x 4.5 axle flange to redrill it to a 5x5 pattern? Axle would be from ab 91-94 Explorer.
  2. Budget36
    Budget36
    Would depend on the diameter of the flange, right? If say it’s 6 inches, then not a lot of meat left after being redrilled. If using 1/2 lugs, the holes abit larger for the splines, leaves less than a 1/4 inch of material to the hole.
  3. AngleDrive
    AngleDrive
    from Florida
  4. AGELE55
    AGELE55
    Never mind...stupid question.
  5. Buy one of those cheap plastic lug pattern measuring tools and stick it on there or a uni-lug rim because those are 4.5 to 5 on the pattern it covers.
    AGELE55 likes this.
  6. Budget36
    Budget36
    No it’s not! I had the same question I asked (different rear though) in another thread. Saved me a few hours heading to pick and pull to measure one myself:)
    Aftermarket axles through Summit, etc aren’t too expensive if you find a rear the proper width.
    AGELE55 likes this.
  7. AccurateMike
    AccurateMike
    AGELE55, Hnstray and clem like this.
  8. gimpyshotrods
    gimpyshotrods
    I believe so. The flanges are fully solid (no extra holes), and machined flat on both sides.
    Going from 4-1/2" to 5" is only a radius change of 1/4".
    I own a few of these. They work as advertised:
    https://www.hellsgatehotrods.com/shop/drill-guide/
    VANDENPLAS and AGELE55 like this.
  9. gimpyshotrods
    gimpyshotrods
    I have a set of these axles in the shop. I can measure the flanges tomorrow.
    AGELE55 likes this.
  10. Budget36
    Budget36
    Color me dumb, I read the original post as going to 5 on 5.5.
    AGELE55 likes this.
  11. gimpyshotrods
    gimpyshotrods
    AGELE55 likes this.
  12. AGELE55
    AGELE55
    Now THAT, is a good idea..
  13. AGELE55
    AGELE55
    So, if I did this, should I weld the existing holes shut?
  14. AccurateMike
    AccurateMike
    No, they're fine. Mike
    clem and Hnstray like this.
  15. ramblin dan
    ramblin dan
    Built a mold about thirty years ago when it was hard to get one of these wheel/bolt check gauges. Here's the measurements of five bolt sizes I used to build it. img024.jpg
  16. 19Fordy
    19Fordy
    Would it be safe to increase the dia. of the original flange by welding a
    ring of steel to the perimeter? Then machine it parallel and flat on both sides.
  17. 1971BB427
    1971BB427
    from Oregon
    No, and it would also cost you more than just having new axles built with a larger flange. But there's another issue with increasing the flange size, and that's the drum. It might not sit inside the drum well if enlarged.
    And don't forget if you redrill the flange, need to redrill the drum also.
    loudbang, AGELE55 and Hnstray like this.
  18. Hnstray
    Hnstray
    from Quincy, IL
    IMO…..totally unnecessary for the example being considered. Look at how the lug stud ‘load’ is imposed on the flange.
    No way is there going to be any load imposed to move the stud outward to the perimeter. And even if there was, the mass of the flange surrounding about 90% of the stud shank is very strong.
    Ray
  19. curious too know if anyone has experienced a failure on any axle flange after a redrill...........given that as stated above axle flange mass is gonna encompass most of the stud, also axles drilled for more than one pattern seem to live just fine. I also think that reduced surface distance between holes ain't that concerning given uniformity through the flange circumference, and flange thickness. Axle quality might come into play as well. Just thoughts.
  20. AGELE55
    AGELE55
    I admire your ingenuity and machining skills. I couldn't drill a straight hole if you held a gun to my head...much less drill it in an exact location.
    I just fired up Ebay and ordered a complete set of lug gauges for any and all possibilities.
    ramblin dan, loudbang and VANDENPLAS like this.
  21. 55blacktie
    55blacktie
    What about balance?
  22. Hnstray
    Hnstray
    from Quincy, IL
    Reasonably assuming the new studs are all the same specs (size and weight) there is no obvious potential imbalance on any affected parts. The studs will be installed evenly spaced on a concentric circle in newly drilled holes. The old stud locations (empty holes) were the same. Any imaginable differences would so small in mass, compared to the axle and flange, and located so near center of mass, as to be negligible.
    Ray
    loudbang, metlmunchr, thintin and 2 others like this.
  23. AngleDrive
    AngleDrive
    from Florida
    Yup, me too
    Budget36 likes this.
  24. AGELE55
    AGELE55
    Well, I missed your link to the re-drill tool until just now. Awesome link. Thanks!
  25. Mike Colemire
    Mike Colemire
    I've redrilled them for 4.75 and threaded them for 1/2 inch screw in studs.
    AGELE55 and loudbang like this.
  26. junkman8888
    junkman8888
    When it wasn't raining today I did some checking: small pattern 8.8" axle flanges are roughly 6-1/4 inches across, big pattern 9" axle flanges are roughly 7-1/4 across. In other words there isn't enough material yo re-drill the small pattern 8.8 axles to the big bolt pattern.
    AGELE55 likes this.
  27. panhead_pete
    panhead_pete
  28. Hnstray
    Hnstray
    from Quincy, IL
    I seriously doubt all 9” Ford axle flanges are the same diameter. What was the wheel bolt circle diameter of the 7 1/4” flanges you measured? And, be honest! :D
    Ray
  29. gimpyshotrods
    gimpyshotrods
    No. There is no need. I have an 8.8 that is re-drilled from 5-lug to 4-lug, and even with two new holes right next to two old holes, it is just fine.
    These are SVT Cobra discs on a 1991 Ranger 8.8, under my '60 Falcon.
    19Eddy30 likes this.
  30. junkman8888
    junkman8888
    Hnstray, to answer your question, you are correct, not all 9" Ford axle flanges are the same diameter, but all those with the big bolt pattern (5 on 5) that I checked were roughly 7-1/4" across, all the 9" small-pattern axle flanges (5 on 4-1/2 ) that I checked were roughly 6-1/4" across. As with anything made by Ford, expect exceptions.
    Note: First post amended.
